2018 Contributors:
Yet another transmission question
66BroncoDD
Post #1 by 66BroncoDD » Mon Mar 03, 2014 10:03 am
I see a pattern developing here :) .
The NV3550 can be done, I see. But it is also a relatively expensive conversion ($900 in adapters alone, and then I have to find the actual transmission). So I got to reading and this toploader (T&C) 4 speed with OD catches my attention. There's PLENTY on how to do the swap to a Bronco with an 8 banger, but as usual the sixes get no love. Ideally what I would like to do is the transmission swap now while I have the frame off (or rather soon to be off) and just stick with my stock 170 until I can build a mean 200. Is that feasible? Does anybody have this transmission, and what was your donor?
Re: Yet another transmission question
Post #2 by bubba22349 » Mon Mar 03, 2014 11:27 am
The T&C top loader (RUG) will fit both sixes and V8's they were used in 1977 & 8 (cast iron looks like a top loader 4 speed but only has four mounting bolts and a bulge on right side of case ) Granada's, Monarchs, Fairmonts, 79 to 83 (alum. case srod) Mustangs etc. there is also the truck version top shifter version (3 speed overdrive bigger bearings used in both 2x4 and 4x4 pickups which you may be able to adapt much easier to your Bronco Check with Advanced Adapters), I don't rember the years think early 1980's to mid 80's. good luck in the hunt :nod:
http://www.advanceadapters.com/tech-vau ... nsmission/
bmbm40
Post #3 by bmbm40 » Mon Mar 03, 2014 7:25 pm
bmbm40
Post #4 by bmbm40 » Mon Mar 03, 2014 7:34 pm
larryejoh
Post #5 by larryejoh » Sun Apr 27, 2014 8:07 am
I'm sorry I just notice this post. I used a mid 80's OD "toploader" it's actually a t-170 RTS which has the shifter tower coming out if the top of the case. I used the 4x4 version which has a 31 spline output and had it cut and resplined to 28. I had it cut to the same length as the original 3 speed and used the 6 cylinder intermediate housing.
chad
Post #6 by chad » Thu Oct 29, 2015 10:13 pm
"...used the 6 cylinder intermediate housing."
the key - they want $300 4 dem now!
