1963 Comet front end
MustangSix
Assistant Admin
Post #1 by MustangSix » Sun May 23, 2004 10:05 pm
The front end parts should bolt in, however you will have to change the pitman arm and idler arm to accomodate the V8 stuff. The engine mounts should fit, but the transmission mount is different and probably will not.
Jack Collins
