2018 Contributors:
Firguring out this R&P thing
StrangeRanger
Post #1 by StrangeRanger » Sat Apr 05, 2003 5:41 pm
All else being equal, SN95 spindles can put you into a bolt on for the PBR brakes, so I'd vote for them
falcon fanatic
Post #2 by falcon fanatic » Sat Apr 05, 2003 10:56 pm
Keep working on it and keep us posted. It's a little too much engineering and fabrication for me to figure out on my own, but I'd love to copy someone else's design!
'63 Futura Convertible. Disc/drum, Bilsteins, beefy swaybars, #480 springs, roller or spherical everything up front, HD shackles on stock springs out back. Megasquirt FI on ported, big valve aussie head w/ roller rockers; 10:1 6000rpm engine; 264/274-12*; C-4, Maverick 8" 3.25 W/trac-lok and perimeter frame inside the unibody. More to come...
http://falconfanatic.blogspot.com/
falcon fanatic
Post #3 by falcon fanatic » Sun Apr 06, 2003 10:33 am
Four lug! Four lug! four lug!
I need one, too.
DaGr8Tim
Re: Firguring out this R&P thing
Post #4 by DaGr8Tim » Sun Apr 06, 2003 11:11 pm
Al wrote:I measured the distance between the inner tie rod pivot points on the center link and measured ~ 25". I have several racks in the garage, but pulled the Escort rack down and measured ~ 22". So, I pulled the boots off the ends to take a look at the outer tie rods on the rack and drew up something. I can make caps that will screw onto the end of the rack in place of the Escort outers that will have a flat section with a tapered hole to accept the stock Mustang tie rod ends. The caps need to be long enough to make up the missing 3". This seems simple enough to do and will be plenty strong.
Al
Speaking of Escorts, the pre-91's had alot of the same suspension and steering parts as the Tempo. The Tempo was afew hundred pounds heavier. Might be able to hold more weight.
A)bort, R)etry, I)nfluence with large hammer
1997 Jeep Cherokee
1975 Jeep CJ5 with a hacked CJ7 tub
Post #5 by Guest » Mon Apr 07, 2003 4:27 am
where are the pic AL ? i,m planning to do the same with the power steering box from a sierra ore scorpio ,gone messure this week the lengte ,and see witch 1 fit,s the best ! btw wil your project for powersteering ore manuel ? i hope the sierra wil fit , because there are tons of sierras here on the yunk yard , got already the calliper ,s from a 4 disk setup from them and the complete cable setup for hand brakes rear , seems to me the same connection to the brake system as the orginal 1 ! btw where is your planning to bolt on the rack ?
CoupeBoy
moving the tie rod mounting locations.
Post #6 by CoupeBoy » Mon Apr 07, 2003 2:00 pm
Al,
Have you looked at the Pro-Engineering Bump Steer Corrector Kit?
BUMP STEER CORRECTOR KITfor '64 1/2 to '70 Mustangs and Cougars. The kit relocates the outer tie rods down 1 inch and forward 1 inch. A must for competition and high performance applications. The Bump Steer Corrector Kit when used with the Neg. Wedge kit produces the ultimate Mustang front suspension. Made from quenched and tempered 4140 Chromoly steel (180 kpsi tensile strength). bolts on, no heating, bending, or spindle modification required. The Bump Steer Kit quickens the steering ratio, by approximately 1/2 turn, and reduces the Ackermann angle (great for additional cornering speed). Recommended for competition use only due to greatly enhanced steering response and some increase in steering effort. Used stock inner and outer tie rods. Specify year/model . . . . . . . . . $239.95
I thought I read somewhere that the adapters move the tie rod mounting location IN 1/4" also, but 240$ for a couple chunks of chromoly really hurt me in my wallet area..
-ron
1970 170/C4
1967 200/C4
1975 250/flexplate
1975 300/flywheel
Users browsing this forum: No registered users and 6 guests
