2018 Contributors:
Idler arm bushing replacement
cballard1972
Post #1 by cballard1972 » Fri Jan 07, 2011 12:33 pm
Getting the sleeve out of the idler arm, to replace the bushing. It appears to be seized in there. I tried heating it with a propane torch. Nothing. I am gonna soak it in penetrating fluid tonight.
65 Falcon 4dr sedan 200CID
63 Galaxy Fastback Project
04 Mustang Convertible
Re: Idler arm bushing replacement
Post #2 by bubba22349 » Fri Jan 07, 2011 2:28 pm
air chizel, or press
cballard1972
Post #3 by cballard1972 » Fri Jan 07, 2011 2:33 pm
And I have neither.lol I do have a compressor, but I do not have an air chisel.
Post #4 by bubba22349 » Fri Jan 07, 2011 3:21 pm
If you get the ruber out of the center than you can use a hack saw cut almost through the bushing in a couple places. Than you can drivr it out with hamer and chizel, punch or ......
You can also get a low priced air chizel at harbor freight.
cballard1972
Post #5 by cballard1972 » Fri Jan 07, 2011 3:23 pm
Thanks Bubba, the rubber came right out, as half of it was missing/worn. :shock: . I will give the hacksaw/chisel a try.
Post #6 by bubba22349 » Fri Jan 07, 2011 3:44 pm
:thumbup:
Users browsing this forum: Google [Bot] and 5 guests
