2018 Contributors:
Keeping an i6 front end
sparkyj
Post #1 by sparkyj » Mon Nov 28, 2011 11:50 am
Hi guys, I bought a V8 front end kit when was thinking of converting the 62 ranchero to a V8 car (many moons ago).
I ended up rebuilding the 6. Are there any parts from the front end kit that could be used on this 6 cyl car?
or should I simply sell the front end kit for the V8 and order a complete i6 front end kit?
I know the tie rods are bigger. I used to know the answer to this question but so much time has passed.....
jamyers
Re: Keeping an i6 front end
Post #2 by jamyers » Mon Nov 28, 2011 6:10 pm
I'm not sure which parts are interchangeable, I think it depends on the kit. Do you know / remember where you got it from, and/or is it OEM or aftermarket? Probably not OEM, since the V8 wasn't an option in '62, but I think there are kits that use OEM parts.
Does the V8 kit require you getting new wheels (5-lugs or otherwise)?
Does the V8 kit include spindles? (I've heard somewhere that the V8 spindles are a good upgrade due to some of the I6 ones being marginal, but then bazillions of I6 front ends are still doing well)
If using the V8 kit means new wheels (and a mix of 5-lugs on the front and 4-lugs on the rear), then I'd sell and rebuild the I6 parts.
If I could upgrade the spindles easily, I'd do that.
James - '62 Ranchero (200cid), '71 LeSabre (464cid)
The ONLY safety device we need is a 6" sharpened steel spike bolted to the center of the steering wheel of EVERY vehicle.
Emergency Rooms and Funeral Homes will be busy for a week or so, then I predict a dramatic drop in vehicle accidents.
CobraSix
Post #3 by CobraSix » Tue Dec 20, 2011 10:02 am
by V-8 front end kit, what do you mean?
I put a V-8 front end on my mustang. Everything but the steering box. The pitman arm for the V-8 set up fit my steering box. After that, it was new spindles, idler, drag link, and tie rod ends.
But again, that's for a mustang. Not sure about the early falcon body if there were differences.
Slade
My Website
My How to's
Engine: 200 CI, Oz 250 modified for 4V Holley 390CFM, DS II Ignition, 40kV Flamethrower, MSD Digital 6+
Drivetrain: Cable Clutch, V-8 T5, 8" 5 Lug Rear End, 5-Lug SSBC Front Brakes, 3.40:1 Posi
