Adding a groove to a 68 crank pulley
68BlueStraight6
Post #1 by 68BlueStraight6 » Sun Sep 04, 2016 6:34 pm
Is it possible to use this: http://www.cjponyparts.com/170-200-cran ... ey/p/CSP3/
On a 68 200. The dates similar parts refer to are for a 65-67. Will this also bolt up to my crank pulley to have a second groove to run a power steering pump?
Thanks,
Kris
Re: Adding a groove to a 68 crank pulley
Post #2 by bubba22349 » Mon Sep 05, 2016 12:26 pm
Dose your 1968 have a three bolt balancer? If it dose it likely will fit. Good luck :nod:
68BlueStraight6
Post #3 by 68BlueStraight6 » Mon Sep 05, 2016 3:40 pm
It does have the three bolt holes. Does this attach with the three bolts or the center crank bolt, or both? Do I need a longer crank bolt? Thanks for the response.
Post #4 by bubba22349 » Tue Sep 06, 2016 1:45 am
It attaches with the three outer bolts plus the center crank bolt. The crank bolt is probally long enough but if you wanted to find another just add the pulley and measure the depth of the crankshaft hole plus the washer and compare that measurement depth as it is now without the add on pulley to the lenght of your existing bolt and washer. Good luck :nod:
