61 to 68 steering gearbox
Corinthian Falcon
Post #1 by Corinthian Falcon » Wed Oct 19, 2016 9:50 pm
I was told by carsteering.com, that the 61 Falcon steering gearbox can be replaced by the 68 Falcon gearbox. They look very close with exception of the long shaft on the 61. What are your thoughts on this? Has anyone compared the two up close and personal?
I'm changing the steering column in my 61 to an aftermarket column, and if the gearboxes can be changed out, that would make the column switch a little easier.
Harold.
mustang6
Re: 61 to 68 steering gearbox
Post #2 by mustang6 » Thu Oct 20, 2016 2:52 am
I'm not sure on the answer to your question, but I happen to have a 68 Falcon steering box I can measure and shoot pictures of if you need. Last year I bought a complete steering setup off a 68 Falcon (mistakenly) believing it would fit a 68 Mustang. I found the steering box to have a slightly different bolt mounting pattern that did not match the Mustang. If we find they do interchange, I would let it go cheap! :)
Scott
Scott
68 Mustang 200 ci, 250-2V head, H/W 5200, Dual Headers, Comp Cams 252H, DSII w/ MSD 6AL, T-5, V8 suspension.
Corinthian Falcon
Post #3 by Corinthian Falcon » Thu Oct 20, 2016 10:01 am
Mustang6 - please, if you don't mind doing the pics and measurements, I would appreciate you doing that for me. I'm in no hurry, so just when you have time.
And you can email them to me. I know that would be easier than posting them.
Thanks.
Harold.
