Tie rod ends - early Comet to Maverick spdls?
powerband
FSP Moderator
Post #1 by powerband » Thu Feb 16, 2017 10:22 am
Plan trying '71 4 lug Maverick spindles on the '61 to be able to use later UCA/LCA/BJ's (upgraded 65 'stang app).
Any simple options for the tie rod end size difference other than the conical adapter sleeves for early small TR ends ?.
Are the early Tie Rods and ADJUSTING SLEEVES smaller threaded end as well?.
I have the complete steering setups from non-power '71 Mav' and a PS '76.
thanks for any pertinent info...
Re: Tie rod ends - early Comet to Maverick spdls?
Post #2 by bubba22349 » Fri Feb 17, 2017 10:36 am
Besides using the tie rod spacers you could re-machine the tie Rod holes in the center link so you could use the later tie rod ends. You might even be able to change over to most all the Maverick parts with the exception of the center link. For a better center link with improved steering geometry look into adapting the 1965 Falcon / Comet V8 part. Good luck :nod:
