61 to 65 V8 steering with 250?.
powerband
FSP Moderator
Post #1 by powerband » Fri Jul 21, 2017 10:17 am
Only in this forum :roll: :
I have a 61 with a 250 in it, the steering center link has been 'flipped' as per FSP handbook to clear the 250's low-mount starter and pan.
Is the 65 V8 steering gear already lower to clear low starter V8's?.
Will '65 V8 steering Pittman/right side Idler arm/center link FIT with clearance the for 250's V8 bell and starter position. ?.
I haven't found any forum member discussions or pics on this yet.
thankx
rocklord
Re: 61 to 65 V8 steering with 250?.
Post #2 by rocklord » Sat Jul 22, 2017 1:35 pm
You may be able to use a PMGR starter to get clearance for your steering.
http://www.fordmuscle.com/archives/2001/08/ministarter/
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
2017 BMW X3, 3.0L Dual Turbo, 300HP, 8-Spd Auto
powerband
FSP Moderator
Post #3 by powerband » Sat Jul 22, 2017 2:31 pm
I am looking to replace the six cylinder steering 'flipped' setup with the V8 steering setup and need to determine if V8 setup will clear the 250 starter/bell/pan.
thanks
61/250 / Hooker dual out headers with PMGR and Six flipped centr link;
