Need to replace the bushings for the rear leap springs and shackles. Looking for the best place to pick them up at.
Rockauto CJpony ?????? Need the leaf spring bolt for the front leaf socket too. Drivers side came right out. But the passenger side...well it was a #$%&#>&^ to get out. Also need the wheel bearings and gaskets that go along with them.
Thanks for you input.
Hump.
2018 Contributors:
2018 Contributors:
Shackles and leaf spring Bushings
- Registered User
- Registered User
Re: Shackles and leaf spring Bushings
When I replaced the rear Springs on mine is got the kit that had Springs shackles and bushings, bolts from mustang unlimited they have the individual parts too good quality and look factory. Had no problem with installing them. And for the seals and barings I just go napa
- Registered User
Thanks 64*5. I'll check my NAPA to see if they got em. Will say this.....ORieley's may be cheaper based on what my brother priced brake calibers for his F150. NAPA wanted close to $100....O's had them for $35/40
Hump
Hump
