Shackles and leaf spring Bushings
Humpbackshooter
Post #1 by Humpbackshooter » Sat Sep 16, 2017 10:56 pm
Need to replace the bushings for the rear leap springs and shackles. Looking for the best place to pick them up at.
Rockauto CJpony ?????? Need the leaf spring bolt for the front leaf socket too. Drivers side came right out. But the passenger side...well it was a #$%&#>&^ to get out. Also need the wheel bearings and gaskets that go along with them.
Thanks for you input.
Hump.
64-5mustang
Re: Shackles and leaf spring Bushings
Post #2 by 64-5mustang » Sun Sep 17, 2017 5:59 pm
When I replaced the rear Springs on mine is got the kit that had Springs shackles and bushings, bolts from mustang unlimited they have the individual parts too good quality and look factory. Had no problem with installing them. And for the seals and barings I just go napa
Humpbackshooter
Post #3 by Humpbackshooter » Sun Sep 17, 2017 11:18 pm
Thanks 64*5. I'll check my NAPA to see if they got em. Will say this.....ORieley's may be cheaper based on what my brother priced brake calibers for his F150. NAPA wanted close to $100....O's had them for $35/40
Thanks
Hump
