2018 Contributors:
Bottom of shocks creaking
StarDiero75
Post #1 by StarDiero75 » Thu Aug 23, 2018 12:37 pm
Howdy guys.
Ive spent a year now on and off trying to diagnose why my front end creaks when someone is in it and by golly i found it! At first i thought it was the control arms, then i thought it was the shock itself, NO ITS THE SHOCK TO THE CONTROL ARM! I put these shocks in about a year ago. My wonder is, was i supposed to grease the bottom of it or something? I shot WD-40 down there and the problem is fixed, but thats not the solution.
It should have 4 doughnut rubber pieces for top and bottom, unless it only had bottom, i cant remember.
This is a 65 Ranchero.
Thanks guys!
--1965 Ranchero w/1966 200, dual friction diaphram 9" Modern Driveline clutch and billet flywheel all balanced, 1985 SVO WC T5 with front shift, 1966 2.8 Ford 8", Weber 32/26 with VI adapter, CRT Performance HEI.
B RON CO
Re: Bottom of shocks creaking
Post #2 by B RON CO » Thu Aug 23, 2018 4:51 pm
Hi, a lot of these cars were squeaking from when they were new and we sprayed a lot of
WD 40 and other snake oil on the bushings, usually at every oil change. Good luck
1966 Ford Mustang - 289 V8
drag-200stang
Post #3 by drag-200stang » Thu Aug 23, 2018 5:20 pm
I would just turn up the radio. :D
Actually had to do that to hear the radio over the headers and thrush straight thru. 8)
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
StarDiero75
Post #4 by StarDiero75 » Fri Aug 24, 2018 2:23 am
So these cars squeaked and creaked brand new?
Nothing like bottom of the line Ford lol
chad
Post #5 by chad » Fri Aug 24, 2018 9:42 am
seems like all cars did & some still do
I kinda like this as a pedestrian..."look'n listen"
62Cometman
Post #6 by 62Cometman » Fri Aug 24, 2018 9:57 am
Ill one up you. My car was nice and quiet suspension wise, and then i took it in to get an alignment. Now the pass side front has a squeak from somewhere. :bang:
1962 Mercury Comet 170 ci, Dagenham Trans, 2.83:1 7.25 rear.
She ain't fast but she's fun. 8)
thestang
Post #7 by thestang » Sun Aug 26, 2018 5:31 pm
62Cometman wrote:Ill one up you. My car was nice and quiet suspension wise, and then i took it in to get an alignment. Now the pass side front has a squeak from somewhere. :bang:
Samething happened to me
