2018 Contributors:
Koni Adjustable Shock Setting
Harlon
Post #1 by Harlon » Wed Nov 07, 2018 1:52 pm
I’m in the process of upgrading the handling on my 66 Mustang.
I recently put on a heavier duty one piece export brace and Monte Carlo bar.
My next step is to upgrade to a 1 inch front sway bar, and new shocks on all four corners.
After much research and forum reading, I've settled on Koni adjustable shocks.
Question: anyone have an opinion on best setting to start. I understand they come from the factory at full soft. I’ve read full soft is good for the rear and from 1/4 to 1 1/2 turns for the front. As most of the reading is using these on V8 cars, I’m wondering what people like for the front shock setting for use with the I6.
Harlon
B RON CO
Re: Koni Adjustable Shock Setting
Post #2 by B RON CO » Sat Nov 10, 2018 10:41 am
Hi, one guideline is soft spring / soft shock, stiff spring / stiff shock. Good luck
1966 Ford Mustang - 289 V8
Post #3 by bubba22349 » Sun Nov 11, 2018 10:58 am
You didn't state which engine your 66 Mustang has, so I am assuming it's a 200 six. The 144 to 200 six's are very light weight compared to the V8's, the 3/4 inch front sway bar works better or you can also a stock V8 Mustang GT front sway bar and are a much better chooice over the 1 inch bar along with a 1/2 inch rear sway bar. On shock setting I would probably go with the soft setting to start and see how much stiffer you want it to ride. Good luck :thumbup: :nod:
65coupei6
Assistant Admin
Post #4 by 65coupei6 » Mon Nov 12, 2018 10:09 am
I have to disagree on the sway bar. I have the 1" with the 200 and it performs well. I don't like rear sway bars on Mustangs.
As for the shock settings. I would start in the middle position and then work from there. Shock settings are kind of like exhaust sounds. Everyone has a preference. My settings are on the stiffer side for the RideTechs's. My buddy was in the car last weekend and said the ride was to stiff. I told him to get out and walk then. :P
...Marco
'65 Mustang Inline 200. VI (CI) Aluminum Head, Holley 350, Schneider 264/274 cam,
Headers, DSII, MSD 6A, and a whole lotta other stuff!
Build That Six With Parts From VintageInlines.com
