<<< New Site Update >>>
Alignment after lower ball joint replacement?
StarDiero75
Post #1 by StarDiero75 » Tue Dec 11, 2018 2:17 am
Howdy guys,
My ball joint from RockAuto is failing within about a year, wonderful. Im gonna replace it with a nice one from NAPA. My only question is, do i need to do an alignment afterwards? This will only be the lower passenger side one. I really don't want to but if need be I will. This is a daily 65 Ranchero that does get up on the highway semi frequently.
Thanks a lot,
Ryan
--1965 Ranchero w/1966 200, dual friction diaphram 9" Modern Driveline clutch and billet flywheel all balanced, 1985 SVO WC T5 with front shift, 1966 2.8 Ford 8", Weber 32/26 with VI adapter, CRT Performance HEI.
B RON CO
Re: Alignment after lower ball joint replacement?
Post #2 by B RON CO » Tue Dec 11, 2018 8:52 am
Hi, since you are not really changing anything that has to do with the alignment you will not need to do an alignment.
You don't need to loosen the tie rod sleeve so it will be as it was before.
Good luck
1966 Ford Mustang - 289 V8
StarDiero75
Post #3 by StarDiero75 » Thu Dec 13, 2018 3:30 am
B RON CO wrote:Hi, since you are not really changing anything that has to do with the alignment you will not need to do an alignment.
Good luck
Sick! Thanks a lot man! I was worried I was seeing another $100+ bill ahead lol
