<<< New Site Update >>>
Tappered reverse inserts
- Registered User
Does anyone know who make a reverse tapered insert for where the steering link goes into the pitman arm. I have a 65 falcon that had a 200-6 in it. Replace it with a 300-6. had turn the streering link upside down. Cause the oil pan would hit it. So I drill the pitman arm with half inch drill bit. Put steering link on. Washer and nut with cotter pin. It's on there. But since the link bolts are tappered. . I am afriad it might wooble. It's good and tight. But woundering if someone makes one. Thanks
- powerband
- FSP Moderator
Re: Tappered reverse inserts
I used a tapered reamer and then used 'Mustang Steve' tie rod end collars .
https://www.mustangsteve.com/tierodbushings.html/
