1963 Ranchero better steering?
papawsfalcons
Post #1 by papawsfalcons » Tue Jun 25, 2019 6:25 pm
My '63 Ranchero has the orignal 6 cylinder 4 lug steering that is hard to steer at low speeds.Hate to park it! I know it the nature of the beast. have owned many many Falcons over the last 45+ years. I need an answer that hopefully not new steerig box at $600-$1000. Changing the steering to "65 help parking? And junk yard electric power steering as I know it whether it works undecided what works easier. What about "63 -"65 power steering. Help and its all about the cost. Thank you.
wsa111
FSP Moderator
Re: 1963 Ranchero better steering?
Post #2 by wsa111 » Tue Jun 25, 2019 8:29 pm
Another option is a ball bearing idler arm. I installed one on my 67 Mustang & it cut steering effort in half.
You may have to have it aligned with +1 positive caster if the steering wheel does not center after a corner.
Check out https://opentrackerracing.com/
bmbm40
Post #3 by bmbm40 » Tue Jun 25, 2019 10:31 pm
What a great solution! Never knew these parts existed. Good resource for many members here.
StarDiero75
Post #4 by StarDiero75 » Thu Jun 27, 2019 4:44 pm
I rebuilt my box for $350 and it seems to work great! If you live near Seattle, Red Head Steering does great
--1965 Ranchero w/1966 200, dual friction diaphram 9" Modern Driveline clutch and billet flywheel all balanced, 1985 SVO WC T5 with front shift, 1966 2.8 Ford 8", Weber 32/26 with VI adapter, CRT Performance HEI.
