Post your best times
Moderator: Race Moderator
AzCoupe
Administrator
Post #1 by AzCoupe » Sun Mar 18, 2007 4:32 pm
I would appreciate if you guys would post your best times/mph, car, and basic mods. Then I can pull the info off here and post it on the new website. Thanks.
EXAMPLE: 63 Falcon - 11.39@120 - 250ci, Turbo, 274H, OZ Head, C4, 3:50-9"
OR: 71 Maverick - 17.51@??? - 250ci, Hooker Header, C4
Looking for Performance Parts, see Classic Inlines
Mike
Click here for larger image & info
Gene Fiore
RC Moderator
Post #2 by Gene Fiore » Sun Mar 18, 2007 9:03 pm
1971 Maverick, 17.51@75.78, stock 250cid, Hooker dual out header, C4
Have not been back to the track yet with the DUI dizzy. :(
1971 Maverick, 250I6, crank knife-edged, Clay Smith 278 solid cam, .040 over 255 V8 pistons, 10.5 to 1, Custom 500 Holley 2V on Classic Inlines Aluminum cylinder head, 1.6 rockers, Hooker header, DUI dizzy, C-4 w/2800 stall, 8" 3.55 det locker
Best ET 1/4 mile: 14.92 at 89.61 mph on 1/12/2013
My Classic Inlines Photo Page
THE FRENCHTOWN FLYER
Post #3 by THE FRENCHTOWN FLYER » Mon Mar 19, 2007 1:20 pm
Edited 5/30/10:
9.00/ 147. Still plenty left to find (if I can keep a head gasket in it it should do 8.8s).
'23T 303 X-Flo head, typical high-dollar bracket racing inards, 5500 Coan converter, Powerglide, 4.30 9".
Also:
'30 Roadster pickup, 300 mild bracket motor w/ 480 Holley, flat top pistons, etc., 4000 Coan converter, Powerglide, 2.47 Rear gears!, 11.68 / 121. 2000 Milan Dragway Street Season Champion
"33 Willys coupe Street Beater, 305 w/ dual 1.08 Autolites, EFI manifolds, hydraulic cam, 2500 CJ converter C6, 3.59 9". 13.44's / 99.
'48 Anglia 240 w/ 390 Holley, 2500 converter C4, 3.00 9", 15.teens shifting at a lazy 5200. Should do 14s next summer with a higher shift point. Son David's car. He's in LA, car lives with me. (ed note: Dave ran a 14.85 summer of '09)
'23T Logghe nostalgia altered, 300 bracket motor, 9.73 / 133. Currently wrecked and awaiting resotration. My first real race car. 1993 Milan Dragway Super Pro Season Champion.
"40s era Indy (big) champ car under construction.
Plus some other V8 powered junk.
Last edited by THE FRENCHTOWN FLYER on Sun May 30, 2010 4:42 pm, edited 3 times in total.
Inline6Merc
Post #4 by Inline6Merc » Mon Mar 19, 2007 2:48 pm
1964 Comet- 200ci, 1.6 roller rockers, headers, daul 1100 carbs, 1969 head with mild port and polish, 2 speed, 3.50 gears
Best time: 20.583 @ 62.17mph (in 1st gear through whole 1/4 mile)
64 Mercury Comet 204c.i.
DUI Ignition
Clifford dual out headers
10.2 to 1 Compression
CI Aluminum Head/Intake Manifold
480cfm Autolite 4 bbl
278 Solid Lifter Cam
1.6 ratio Roller Rockers
2500 Stall Converter
C4 Transmission
3.50gears
8inch Rear End
82F100
Post #5 by 82F100 » Mon Mar 19, 2007 3:56 pm
82 ford shrtbed 300/ c-6 3.55 gears and Mac headers 17.63 @ 84 mph
300's make good truck motors....not race motors
mcmillal
Post #6 by mcmillal » Mon Mar 19, 2007 4:06 pm
17.095 sec @ 78.25 mph (uncorrected)
Early small log head with adapter mounted carb.
See my signature other for mods
...........Cheers, Alex
Alex
68 Mustang 200cid, Clifford 6-1, Duraspark II, Holley 2300(500cfm), MSD-6A, Granada disk brakes, 8" posi rear w/3.25 gears, C4 w/shift kit, custom sub-frame connectors, Z28 style exhaust
63 Triumph TR4
84 Honda Nighthawk S
Aerowrench
Post #7 by Aerowrench » Fri Mar 23, 2007 11:48 pm
THE FRENCHTOWN FLYER wrote:<==
9.04 / 146. Still plenty left to find (if I can keep a head gasket in it it should do 8.8s).
Have you considered O-ringing the head?
wsa111
FSP Moderator
Post #8 by wsa111 » Sat Mar 24, 2007 4:44 pm
1/8 mile 95 degrees temperature, 2.83 rear end ratio.
10.69 @ 67 mph.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
80Stang
Post #9 by 80Stang » Sun Mar 25, 2007 3:43 pm
17.04 @ 81.6mph (@81F)
'80 Mustang NB w/200 w/mild mods
274H, 2V Loghead, T5, 3:08-8.8"
(details at my website)
Post #10 by THE FRENCHTOWN FLYER » Thu Mar 29, 2007 2:34 pm
Yes, I tried that (actually, the block).
Linc's 200
Post #11 by Linc's 200 » Fri Mar 30, 2007 6:48 am
In my sig below.
All my 60' times are total crap.
Gene Fiore
RC Moderator
Post #12 by Gene Fiore » Tue Apr 17, 2007 11:16 am
UPDATED:
1971 Maverick, 17.35@75.78, stock 250cid, Hooker dual out header, C4, FSP DUI Dizzy
Does10s
FSP Moderator
Post #13 by Does10s » Tue Apr 17, 2007 3:57 pm
Oh I gotta update this!
10.95@124 as of 04/14/07.
I need to change my sig too!
Will
'86 Mustang, Turbocharged, Best ET: 10.70@132.
'69 Mustang Sportsroof, 351w, auto
'63 Falcon, Turbocharged 250, C4, 9", Best ET: 10.64@127mph 11/21/14
Linc's 200
Post #14 by Linc's 200 » Wed Apr 18, 2007 5:17 am
Does10s wrote:Oh I gotta update this!
Kelly's car?
Man, that is smokin' fast!!!!!!
cometguy
Post #15 by cometguy » Fri Apr 20, 2007 8:22 pm
'72 Maverick 15.30@85mph 200"/C4 8"-4.62 Legal IHRA Stocker
Post #16 by Guest » Sat Apr 21, 2007 10:27 pm
1966 Mustang 16.23 @ 84.46 mph. 206 ci, 3.80 gears, 3500 stall, 274 cam modified log head, 2 bbl Holley, Pacemaker headers.
Post #17 by THE FRENCHTOWN FLYER » Sun Apr 22, 2007 10:10 pm
UPDATE: 4/22/07
Season opening race at Milan Dragway, Milan, MI
The FTF ran a personal best today of 9.0388 e.t. @ 147.09 mph.
nitrousnick
Post #18 by nitrousnick » Wed May 23, 2007 4:41 pm
68 mustang-11.84@110-300,nitrous 100shot,553 246,256@.050
1 3/4 header,11to1,10inch converter,4.11-9,10.5x28 slicks
Linc's 200
Post #19 by Linc's 200 » Thu May 24, 2007 12:12 am
nckwiencek wrote:68 mustang-11.84@110-300,nitrous 100shot,553 246,256@.050
OK - let me translate this into english for everyone:
1968 Mustang, ran 11.84@ 110 MPH in the 1/4 mile
300 cubic inches, with a 100 shot of nitrous
Cam lift is .553"
Cam duration is: Intake 246*, exhaust 256* @ .050"
1-3/4" tube headers
11 to 1 compression ratio
10 inch torque converter
4.11 gears in a 9" rear end
10.5 x 28 slicks
Post #20 by Guest » Thu May 24, 2007 6:45 am
Whoops!
Need to update mine too...
Best ET 16.11 @ 83.65 mph
sixpak
Post #21 by sixpak » Mon May 28, 2007 8:59 am
72 Cj5, 280 ci, MPI injected, hand fabbed intake, flat tops, under .500 cam, ported, stock valves
7.06 at 97.5 MPH in the 1/8th-----5/25/07 Natinal Trails, Columbus Ohio
Have you been beaten by an inline, lately?
Linc's 200
Post #22 by Linc's 200 » Mon May 28, 2007 1:59 pm
sixpak wrote:7.06 at 97.5 MPH in the 1/8th--
That IS fast!
sixpak
Post #23 by sixpak » Mon May 28, 2007 8:41 pm
Thanks for the props. Now if I could just get the car to leave on the trans brake instead of just flat footing it! I normally 60 ft that 1.66 in the dirt with the brake. Boy it was fun to play on the asphalt! I love the water box!
MarkZE
MarkZE Cortina Times
Post #24 by MarkZE » Wed Jun 27, 2007 12:55 am
1977 Aussie Ford Cortina
250 Crossflow alloy head
Custom T04 turbo setup and Autronic EFI
C4 with transbrake
Track 9 9" diff with full spool and billet axles
28x10.5" M/T slicks
9.58 @ 139 mph
Quicker time to come once I fix my shattered tailshaft yoke and bolt on my bigger turbo.
You can see some pics of the build up over the years at the link below. It needs updating, I have convo pros bigger slicks and a different turbo setup on the car nowdays.
http://fordcortina.com.au/gallery/thumbnails.php?album=47
SuperDave1721
Update the Anglia times
Post #25 by SuperDave1721 » Mon Aug 20, 2007 8:07 pm
[quote="THE FRENCHTOWN FLYER"]<==
'48 Anglia 240 w/ 390 Holley, 2500 converter C4, 3.00 9", 15.90s on a broken trans, should do 14s eventually.
Dad,
You'll need to update the Anglia numbers with the 15.190 @ 88.5 mph pass!
-SD
pro94
Post #26 by pro94 » Sun Sep 16, 2007 12:50 pm
1960 falcon 2dr, 79' 200 I6, with duraspark ignition, accel coil, 2 1/8th exhaust with 50 series deltaflow flowmaster, c4 trans with shift kit, 3.90 gears. 11.81 @ 57.78mph with 2.58 60ft, in 1/8th mile. car weighs 2520lbs with 1/2 tank of gas.
1994 ranger, 5.0, c4, 8.20 @ 80.64 mph 1/8th
1987 mustang lx, 5.0, aod, track whore
1960' falcon, 79' 200 I6, C4 shift kit, 3.90 gears, 11.81 @ 57.78, 2.58 60 ft, in the 1/8
2004 mustang, v6 auto, pony package, x pipe and dual exhaust, k&n, comp orange
Post #27 by Guest » Wed Sep 19, 2007 6:29 pm
Gotta update this :D
1966 Mustang, 206 ci, 3.80 gears, 3500 stall, 274 cam, Aluminum Classic Inlines head, 500 cfm 2 bbl Holley, Pacemaker headers, DUI ignition.
Gord
Times
Post #28 by Gord » Wed Oct 03, 2007 10:13 am
1964 Mustang 300 six
Clifford dual 4bbl intake
comp solid cam, roller rockers
BME rods & pistons
G Force 5 speed
Ran 12.20 110 mph
82F100
Post #29 by 82F100 » Wed Oct 03, 2007 11:20 am
Gord ,Got any pics of your ride?
Smiley84
Post #30 by Smiley84 » Wed Oct 03, 2007 11:37 pm
1984 ford mustang coupe, 2700 pounds, rebuilt to stock specs 1981 200ci. Accel coil, c3 and 4.10s w/trac lok.
Reaction--------0.514
60ft-------------2.472
330ft------------7.168
Mid Mph--------60.15
660ft------------11.219
990ft------------ N/A
1/4Mph---------74.01
1/4ET-----------17.819
Gord
Pictures
Post #31 by Gord » Thu Oct 04, 2007 3:59 pm
Sure do send me an email gord@cowanagencies.com and I will send some great photos by return, then maybe I could get you to post them for me. Our track photographer got some great shots this year.
cometguy
Post #32 by cometguy » Mon Oct 22, 2007 11:10 pm
cometguy wrote:'72 Maverick 15.30@85mph 200"/C4 8"-4.62 Legal IHRA Stocker
New PB for the car; changed to 5.43 gear and 28" tire - 15.25@86.88mph
83F150
Post #33 by 83F150 » Tue Oct 23, 2007 12:04 pm
I would be scared to know what my 300 runs in the 1\4....
I clocked it to 60 the other day....13 seconds :P
My 83 Ran it in like 9.....course it had a 4sp and 4.11's.
heck even the dually pulls it off in 11.
Fastest thing i own.....69 Charger R\T 13.5@98MPH. 440 Big block\4sp.
Or do you only want 6 cyl times?
[/quote]300's are known for that. Even running on 3 cylinders upside down without oil or coolant they'll still pull a locomotive up a hill, albeit at 5 mph..... OK so maybe that's a bit of an exaggeration but you get the idea....[/quote]
96 F150 4x4 300\E4OD\3.55's
78 F350 DRW 2wd 400\4sp\4.30
08 Colorado 2wd 2.9L\5sp\3.73's
Not my only vehicles....
80Stang
Post #34 by 80Stang » Fri Nov 16, 2007 6:38 pm
80Stang wrote:17.04 @ 81.6mph (@81F)
Update: 16.89 @ 82mph in August this year.
Gene Fiore
RC Moderator
Post #35 by Gene Fiore » Fri Nov 16, 2007 7:53 pm
That's great. :wink:
sixpak
Post #36 by sixpak » Mon May 26, 2008 6:14 pm
280 injected JEEP, under .500 lift cam, ported head, stock valves
11.22 @117 flat footing it. National trails, columbus ohio
82F100
Post #37 by 82F100 » Mon May 26, 2008 8:22 pm
Sixpak, got any pics?? Thanks for posting 8)
sixpak
Post #38 by sixpak » Mon May 26, 2008 11:25 pm
82F100
Post #39 by 82F100 » Tue May 27, 2008 3:49 am
:thumbup: thanks, nice wheels up shot on the pavement.
Rns13
Post #40 by Rns13 » Mon Jun 02, 2008 6:55 am
Ford Cortina
2750lbs
250 xflow
Alloy head
Big cam
650 mighty demon
N/A
C4
3.89 gears
12.24 @ 109mph
Whats the fastest N/A ford six street car in the world???
fast64ranchero
Post #41 by fast64ranchero » Sun Aug 17, 2008 9:21 pm
1978 Ford Fairmont
off set ground crank to 4.125
Manley Rods
CP pistons
62-1 turbo
Tremac TKO 5 speed
3.08 gears
60 foot; 2.306
330; 5.802
1/8; 8.489, 92.58mph
1000; 10.752
1/4 12.635 @ 120.08mph/now 12.33@123.49
full street trim!!!! and pump gas
Last edited by fast64ranchero on Fri Nov 21, 2008 2:40 pm, edited 1 time in total.
Post #42 by Guest » Sat Sep 20, 2008 5:54 pm
Heres my best time so far. :D
60' 2.05 1/8 mile 9.28 @ 74.85 1/4 mile 14.58 @ 92.00
Naturally aspitrated, Classic Inlines aluminum head, 4 Bbl Holley, DUI distro, many mods, 2784 pound 66 Mustang coupe.
66Sprint6
Post #43 by 66Sprint6 » Sat Sep 20, 2008 10:34 pm
My times are HORRID, near embarrasing for all that ive done, but I blame the stock open rear end and 2.73 gears LOL These are all with the 200 with forged .060 pistons, 274 cam, buick GN turbo and Quick Fuel 2300 2 barrel. The 1/8 mile time was on 10psi and the 1/4 time was after I got tired of runnin so slow and cranked it to 14psi.
Best run down the 1/8 mile track
60ft--------2.3789
330ft-------6.4319
594ft-------9.1458
1/8 ET-----9.7599
1/8 MPH---73.28
Best run down the 1/4 mile track
60ft--------2.397
330ft-------6.400
594ft-------x
1/8 ET------9.612
1/8 MPH---76.14
1000ft------x
1/4 ET------14.677
1/4 MPH---97.28
My 60fts STINK, and my MPHs are much better than my ETs LOL. I got alot of work to do!
Matt
"ITS A SIX!!!!!"
Gene Fiore
RC Moderator
Post #44 by Gene Fiore » Sat Oct 11, 2008 11:19 pm
Gotta update this! :wink:
UPDATE: 71 Maverick, 250cid, Holley 350 Holley 2V direct mount on log head, mild port and polish, Hooker headers, FSP DUI dizzy, C-4, 8 inch w/3.55's and detroit locker:
Reaction: .095
60 ft: 2.229
1/8 mile et: 10.367
1/8 mile mph: 65.42
1/4 mile et: 16.351
1/4 mile mph: 81.77
Gene Fiore
RC Moderator
Post #45 by Gene Fiore » Sun Nov 16, 2008 6:13 pm
Another UPDATE: 71 Maverick, 250cid, Holley 350 Holley 2V direct mount on log head, mild port and polish, 1.6 rockers, Hooker headers, FSP DUI dizzy, C-4, 8 inch w/3.55's and detroit locker:
Reaction: .03
60 foot: 2.219
1/8 mile et: 10.31
1/8 mile mph: 65.47
1/4 mile et: 16.32
1/4 mile mph: 81.39
Crosley
Post #46 by Crosley » Sat Mar 07, 2009 8:21 pm
March 7 - 2009 ;
1962 Falcon;
1978 200cid engine - fresh. Clay Smith cam , milled head , 2 barrel Holley adapted to the 1 barrel hole, headers
ET: 16.32
MPH : 83.09
Tony in AZ...
"130 mph is known as first gear at the Bonneville Salt Flats"
Gene Fiore
RC Moderator
Post #47 by Gene Fiore » Sat Mar 07, 2009 11:18 pm
Next weekend should be interesting!! :wink:
Does10s
FSP Moderator
Post #48 by Does10s » Mon Mar 09, 2009 9:59 am
Man Gene, you and Crosley are neck & neck!
I wonder who runs out to the local speed shop and picks up a "Sneaky Pete"?
See ya both on Friday and Saturday!
We'll try and save ya some pit space....but no guarentees!
Later,
Will
Gene Fiore
RC Moderator
Post #49 by Gene Fiore » Mon Mar 09, 2009 3:57 pm
Does10s wrote:I wonder who runs out to the local speed shop and picks up a "Sneaky Pete"?
Nah...all throttle no bottle for me! See ya Saturday. :D
Crosley
Post #50 by Crosley » Mon Mar 09, 2009 10:25 pm
i should be out there saturday.
My falcon ran in the 16.30s on the 3 runs last weekend. 16.35 , 16.38 , 16.32... I had hoped it would pick up a bit more with the 2 barrel on it..
On the flip side; with the 2 barrel carb adapted onto the 1 barrel log manifold is like stuffing 10 pounds of stuff through a 5 pound hole.
I still have not messed with the OE dizzy advance curve yet.
Tony in AZ...
