Post your best times
Moderator: Race Moderator
john-dickjr
Re: Post your best times
Post #101 by john-dickjr » Thu Jan 06, 2011 9:38 pm
just talked to charlie, best time in the 1/8 is a 7.39 and having issues with it, he is taking some pictures for me , i will post them when i get them..
getting it done with 6 what it takes you to do with 8
nitrousnick
Post #102 by nitrousnick » Sat Jan 08, 2011 2:33 pm
13.2 @ 102
11.61 @ 116 with 100 shot of NOS
THE FRENCHTOWN FLYER
Post #103 by THE FRENCHTOWN FLYER » Sat Jan 08, 2011 5:45 pm
nitrousnick wrote:13.2 @ 102
sweet
Mustang_Geezer
RC Moderator
Post #104 by Mustang_Geezer » Sat Jan 08, 2011 7:32 pm
Heres the link to the time slip scan for my very best pass. :)
http://www.dragtimes.com/1966-Ford-Must ... 20114.html
I'm car number 206 on the timeslip.
Later,
Doug
1966 Mustang Coupe
206 ci Inline 6
Best ET 60' 1.84 1/8 mile 8.74 @ 79.09 mph 1/4 mile 13.67 @ 98.18 mph US 131 Motorsports Park. 4/6/13
2003 F-150 FX-4 Tow vehicle.
9500rpm
Post #105 by 9500rpm » Sun Jan 09, 2011 3:34 pm
1961 falcon coupe
240ci .60 over cleveland head hilborn soilid roller 14.2.1 custom rods almost stock crank 8800rpm
close top loader 9'' 430gears 890 15 slicks
2480lb with driver
10.982 with alot of tire spin 1st and 2nd
82F100
Post #106 by 82F100 » Sun Jan 09, 2011 4:01 pm
9500rpm wrote:1961 falcon coupe
2480lb with driver
Neat combo, old H/MP car? Gotta see pics of this one 8)
300's make good truck motors....not race motors
Gene Fiore
RC Moderator
Post #107 by Gene Fiore » Mon Apr 11, 2011 10:29 am
15.26 at 88.27 mph on 4/10/2011
1971 Maverick, 250I6, crank knife-edged, Clay Smith 278 solid cam, .040 over 255 V8 pistons, 10.5 to 1, Custom 500 Holley 2V on Classic Inlines Aluminum cylinder head, 1.6 rockers, Hooker header, DUI dizzy, C-4 w/2800 stall, 8" 3.55 det locker
Best ET 1/4 mile: 14.92 at 89.61 mph on 1/12/2013
My Classic Inlines Photo Page
FalconSedanDelivery
250 Log 3 Carbs
Post #108 by FalconSedanDelivery » Tue May 10, 2011 12:18 am
Finally got to test My 250 Engine ,in My 65 Mustang , Best Et was 14.55 @ 90.97, Terrible 60ft times ( Need More Converter ) will be installing a Higher stall unit to be ready for the 3 day race at my home track, 13's should be the result " Beaver Springs Dragway ", --http://beaversprings.com/ 250 .040, 1100 center, Little Holleys on ends , Crane Solid Cam .460int, .480exh Duraspark ign with GM 4 pin Module , 12-1 compression ( head was milled .120 , Deck .100 , Clifford Headers twin outlet ( open exh Drag car only ) car is a 1965 Mustang 3.50 gears C-4 with 10 inch converter ,( out of my 68 Blown 390 car ) 26.5 Slicks , Moroso Electric Water pump drive , adjustable Rockers , port divider in head , shift at 5000 , 4300 thru the traps
http://www.facebook.com/photo.php?fbid= ... =1&theater
Last edited by FalconSedanDelivery on Wed May 11, 2011 1:50 pm, edited 1 time in total.
Falcon 6's, FE's I Like them both , Sold all My 6 cyl stuff ( for now at least ) glad to pass along some tips though
Gene Fiore
RC Moderator
Re: 250 Log 3 Carbs
Post #109 by Gene Fiore » Tue May 10, 2011 3:15 pm
FalconSedanDelivery wrote:Finally got to test My 250 Engine ,in My 65 Mustang , Best Et was 14.55 @ 90.97, Terrible 60ft times ( Need More Converter ) will be installing a Higher stall unit to be ready for the 3 day race at my home track, 13's should be the result " Beaver Springs Dragway ", --http://beaversprings.com/ 250 .040, 1100 center, Little Holleys on ends , Crane Solid Cam .460int, .480exh Duraspark ign with GM 4 pin Module , 12-1 compression ( head was milled .120 , Deck .100 , Clifford Headers twin outlet ( open exh Drag car only ) car is a 1965 Mustang 3.50 gears C-4 with 10 inch converter ,( out of my 68 Blown 390 car ) 26.5 Slicks , Moroso Electric Water pump drive , adjustable Rockers , port divider in head , shift at 5000 , 4300 thru the traps
That's awesome...sounds like the motor really wakes up with the 3 carb setup. Except for that and the compression we have similar builds yet you are running almost a second quicker currently. Can you post your best timeslip?
FalconSedanDelivery
Post #110 by FalconSedanDelivery » Wed May 11, 2011 1:53 pm
My Car is Drag only , and I suspect ( not weighed yet ) that its about 2600 or less ,that is a big difference , here is the pass
http://www.facebook.com/media/set/?set= ... 1071873567
FalconSedanDelivery
13's This Sunday
Post #111 by FalconSedanDelivery » Thu May 19, 2011 2:23 am
Looks like weather will finally be ok , at my home track they have on 3 completed races , should be 7
Changed the converter , will post the slip
64 200 ranchero
Post #112 by 64 200 ranchero » Sun May 29, 2011 3:05 pm
FalconSedanDelivery that is fast, how much power are you making?
60 ford ranchero daily driver. 200 tri power, modified c4 trans, ds2 distributor, msd programable 6al2, weber ict's, 8" rear end with full spool, 3.80 gears, 245 tires, CI dual out header, Dynomax muffler, 114hp shot wet nitrous kit. JE Forged pistons, 280 110lc cam, around 11-1 compression.
FalconSedanDelivery
Post #113 by FalconSedanDelivery » Mon May 30, 2011 10:15 pm
HP , I'm estimating about 165 at the rear wheels , The weather at my Track was not the best for improvements , but I still was able to improve the ET to 15.54 ( a whole hundredth LOL ), but I did get the mph to 91.76 BUT givin the weather was Hot and Humid and I use My Brothers 302 66 Mustang as a gauge on track conditions Good or Bad Day ( I also build his engines and drivetrain ) and he was almost a 1/4 second slower than the week I ran the 14.55 @ 90.76 it was a good improvement , more to come.
Gene Fiore
RC Moderator
Post #114 by Gene Fiore » Mon May 30, 2011 10:24 pm
FalconSedanDelivery wrote:HP , I'm estimating about 165 at the rear wheels , The weather at my Track was not the best for improvements , but I still was able to improve the ET to 15.54 ( a whole hundredth LOL ), but I did get the mph to 91.76 BUT givin the weather was Hot and Humid and I use My Brothers 302 66 Mustang as a gauge on track conditions Good or Bad Day ( I also build his engines and drivetrain ) and he was almost a 1/4 second slower than the week I ran the 14.55 @ 90.76 it was a good improvement , more to come.
You meant 14.54...right?
FalconSedanDelivery
Post #115 by FalconSedanDelivery » Mon May 30, 2011 11:08 pm
Yes , LOL , I am so Sun burnt I think my Brain is Fried !!
wsa111
FSP Moderator
Post #116 by wsa111 » Tue May 31, 2011 9:52 pm
Faron, you are getting close to the 13 second plateau.
Since you installed the converter the ET has improved.
However since your trap speed improved in the hot weather do you think you may be on the lean side since the heat improved your trap speed????
My personal opinion is that you need a more agressive camshaft with over .525" lift, 1.65 roller rockers & more exhaust duration due to the poor exhaust flow with the log head???
More differential gear to get your rpms at the eyes closer to 5K
You are a professional so i'm sure you will achieve your goal. Bill
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
FalconSedanDelivery
Post #117 by FalconSedanDelivery » Sun Jun 05, 2011 7:52 pm
Update , weather still not great and carbs still need adjusting/jetting , and I changed the Center carb , to a different 1101 it liked it but also was too lean on the mid track and top end , had a best 60ft of 1.915and , I ran a best of 14.39, on The Brakes hard , I bracket race so I took my best previous pass and looked at the number through the 1000 ft mark , and it looks like it would of ran a 14.29-31 if I had been able to stay in it and around 93/94 mph , Next week my track is closed for the IHRA Points Series ( what I race ) so I have 2 weeks to improve , found a Ton of ET and Power By backing off the total timing to 30 degrees its all in at 2350 , 13's are in site !!
82F100
Post #118 by 82F100 » Sun Jul 10, 2011 11:16 pm
Falcon,keep us updated, can't wait to see what it runs this fall when It cools off 8)
SuperDave1721
Post #119 by SuperDave1721 » Wed Jul 13, 2011 11:42 pm
THE FRENCHTOWN FLYER wrote:Update from the summer of '09:
David's 240 Anglia ran a best-to-date 14.85 @ 90+.
My Willys ran a best-to-date of 13.44.
Another great night out last Wednesday. Made a dozen passes in the Anglia. Mostly trying to get it to leave and run consistently. 14:87 @ 91 was the best with a stiff headwind, but the .489, .509, .521, .523, .523, .535, .565 RT lights (+.500 perfect) were a huge improvement.
Hopefully we'll make it out to a Nostalgia Drags outing in September with the fleet.
-SD
Post #120 by THE FRENCHTOWN FLYER » Mon Jul 18, 2011 10:26 am
Superdave, You forgot the .507 on your last pass. I took some videos of the Anglia. I'll post them soon. We are hoping to run three cars at the Milan Nostalgia Drags in September if time and schedules permit.
For those who don't know Superdave is my son who lives in California. He comes east every summer and we get out his Anglia which he keeps at my place only once a year for some fun.
Love you SD.
FalconSedanDelivery
Post #121 by FalconSedanDelivery » Tue Jul 26, 2011 3:18 am
Some here may already know , but Ive , put the Log head 255 Tri Power Engine , for sale , so the Best of 14.39 @91.76 in Hot air will stand for the immediate future , the Engine was not built to Bracket Race , its plenty tough , just not consistent enough, +or- a 10th on a run will make you the second place finisher in a 2 man race, If I do not sell it it Probably will go in my 62 Falcon Sedan Delivery ( as it was originally built for ) it will be in front of a T-5 and I am sure I will see what it does , but until then its for sale ( in another post ) thanks for encouragement from some, but I am in a points race at my track and I was able to get my low budget 351w together earlier than planned , its in now and working well 12.91@102.64 just 2 races in , expect 12.50's when sorted out , I love My 255 6 and had some people tell me i should not of switched , but as I said it was never planned that way , but was fun while it lasted , thanks Faron
1-fast-6
New Member
Post #122 by 1-fast-6 » Tue Aug 09, 2011 12:13 am
No times to post here as I am not a drag racer but a sports car racer. I run my 65 Mustang in SCCA Solo 2 or otherwise known as Auto Cross. Just thought some of you guys would find what I have done to the engine and car interesting.
1965 Mustang Notchback Coupe
250 inline 6
170 head
adjustable rockers
double dampened valve springs
Silid lifter cam
Hooker Dual Exhaust Header
Mallory YC Series Dual Point Distributor
Offenhauser Intake Adapter with 3 Autolite 1100 series Carbs
13.75:1 Compression Pistons
Aluminum Flywheel
11" Clutch
Close Ratio 4 speed
9" rear end from a 57 Fairlane Station Wagon
4.11 Detroit Locker
Never had the car on the drag strip. The suspension is set up for the turns with the SCCA. Might be interesting to see what it would do though. Not even sure what my horse power is. All I know is it seems to have more than my newer SVT Cobra.
64 200 ranchero
Post #123 by 64 200 ranchero » Tue Aug 09, 2011 12:15 am
wow! :shock: :shock: :shock:
Post #124 by THE FRENCHTOWN FLYER » Fri Aug 26, 2011 11:20 pm
THE FRENCHTOWN FLYER wrote:Superdave, You forgot the .507 on your last pass. I took some videos of the Anglia. I'll post them soon. We are hoping to run three cars at the Milan Nostalgia Drags in September if time and schedules permit.
Love you SD.
Time finally permits. Enjoy.
He's booked a flight back home to run the Nostalgia Drag Weekend
http://www.youtube.com/watch?v=-taX-TKpQbw
SuperDave1721
Post #125 by SuperDave1721 » Mon Sep 26, 2011 12:06 am
Updated video from July's test and tune with the 240cid Anglia. Nostalgia Drag pix coming soon.
http://youtu.be/BiQObpmklVc
-SuperDave
Gene Fiore
RC Moderator
Post #126 by Gene Fiore » Mon Dec 05, 2011 12:29 am
New personal best today but only by 5 hundredths...15.21 @ 87.80 miles per hour.
FalconSedanDelivery
Post #127 by FalconSedanDelivery » Mon Dec 05, 2011 1:48 pm
In your other post you quote a different MPH , is that a misprint or did you combine your best ET and MPH here , just wondering ?
Gene Fiore
RC Moderator
Post #128 by Gene Fiore » Mon Dec 05, 2011 2:42 pm
FalconSedanDelivery wrote:In your other post you quote a different MPH , is that a misprint or did you combine your best ET and MPH here , just wondering ?
Not a misprint...the numbers that I post are always from the same run...I'm not combining.
Crosley
Post #129 by Crosley » Sat Jan 14, 2012 7:37 pm
I made the road trip to SpeedWorld today.
After several changes the past few months and no track time, I finally got to the drag strip.
My Falcon ran a 15.65 off the trailer, it has never run that quick. Previously it ran a 15.70 , but I could never back that up.
Today It ran 15.49 at 86.79 mph.... a few runs later it ran a 15.44 at 85.83 mph. I made no jet changes or timing adjustment at the track , it was running good, so I left it alone
The car sounds slightly different with the new collector setup I built. Previous header setup was 3 into 2 , now it is 3 into 2 into 1 ... stil sounds like an angry chain saw, just different.
Not to bad a mild pump gas 200 CID engine
Tony in AZ...
"130 mph is known as first gear at the Bonneville Salt Flats"
Gene Fiore
RC Moderator
Post #130 by Gene Fiore » Sun Jan 15, 2012 12:41 am
Crosley wrote:I made the road trip to SpeedWorld today.
That sounds great! Was this with the new metering block?
Crosley
Post #131 by Crosley » Sun Jan 15, 2012 6:04 pm
Gene Fiore wrote:That sounds great! Was this with the new metering block?
New billet metering block is on the carb.. I tried a similar jet setup the carb guy posted for your car Gene. My engine would hardly idle or run . I guess the different nozzles affects something? My carb has stock nozzles in the venturi . My meter block is in near stock configuration at this point per the Quick Fuel web site. i did jet the carb down slightly from what I was running last year
Also ... on the header collector, I had a brain fart on the previous post. The header is a 6 pipes into 2 collector design. I changed it to a 6 into 2 into 1 collector. I built a collector add on that merges the two 2.5 inch collector tubes into one 3 inch collector.
Guess I need a larger cam or high ratio rocker arms , bigger valves in the head (mine are stock) and , and , and
Tony in AZ...
Post #132 by THE FRENCHTOWN FLYER » Sun Jan 15, 2012 10:52 pm
Good show!
ares66inline
Post #133 by ares66inline » Fri Feb 24, 2012 12:47 am
'66 Mustang 200ci. Classic Inlines stainless header/dual exhaust, DUI Electronic Ignition, Autolite 1100 with Classic Inlines Remote Induction Kit, stock 2.83 gears, C4 tranny, stock head, stock internals, head gasket starting to leak externally.. :\
1/4 mile:
19.531 @ 64.941mph :|
MPGmustang
FSP Moderator
Post #134 by MPGmustang » Fri Feb 24, 2012 12:55 am
ares66inline wrote:'66 Mustang 200ci. Classic Inlines stainless header/dual exhaust, DUI Electronic Ignition, Autolite 1100 with Classic Inlines Remote Induction Kit, stock 2.83 gears, C4 tranny, stock head, stock internals, head gasket starting to leak externally.. :\
1/4 mile:
I wonder if a bigger jet in the 1100 would help, I know stock is pretty small and leans out alot at higher rpm's. but you got up to 60mph is LESS than 20 SECONDS!! that's good :thumbup:
65mustang-SOLD-200ci-t5-scarebird disks-vintage air ac-264/274 110 cam-mav 8inch 3.8 open-350cfm-CI headers
66 Bronco-SOLD-i6 170 - rust bucket never ran...
75 bronco-SOLD-v8 c4 dana 20 33's and disk brakes, locker front/rear.
Post #135 by THE FRENCHTOWN FLYER » Fri Feb 24, 2012 9:03 pm
MPGmustang wrote:...leans out alot at higher rpm's.
How do you know that?
ares66inline
Post #136 by ares66inline » Sun Feb 26, 2012 6:43 pm
1/4 mile:
I bet it would. I plan on getting the aluminum head with a 2v carb in a few months, also I want to swap out the rear end soon. So this was just preliminary testing to see what the mostly stock setup would do. 8)
Gene 64 2dr
Post #137 by Gene 64 2dr » Wed Jul 18, 2012 9:10 pm
Finally got to the track this year with a much improved time from last years 16.73 @ 79.09
Now 16.371 @ 81.43
Improvements: ET street radials, sub frame connectors, better jetting on carbs, cold air intake
I think there is still a little more room for improvement
Gene
65 Falcon Futura hardtop, FSD’s 250, T5, 4:11’s
Crosley
Post #138 by Crosley » Sun Sep 30, 2012 1:20 pm
I've not run my Falcon in several months.
I added a fresh air intake that pulls air in from right side head light opening. I removed the headlite assembly.
The car ran a 15.342 at 87.69 mph. I can tell the engine likes more air, it sounds better, pulls a little harder the last half of the track.
I only made 2 runs at Speedworld last night. Odd how that place can go to a cluster #@*&@ with delays. The scoreboard still sux , not working correct
Tony in AZ...
Gene Fiore
RC Moderator
Post #139 by Gene Fiore » Sun Sep 30, 2012 3:01 pm
Crosley wrote:I've not run my Falcon in several months.
Wow, that's an awesome time...congrats! Got any pics of the fresh air setup? Did you use a carb hat?
Crosley
Post #140 by Crosley » Sat Oct 13, 2012 11:35 pm
My 1962 Falcon ran a best of 15.18 at 87.77mph today at SpeedWorld. My fresh air intake from the headlite seems like a winner to get air into the log head a little easier.
Unfortunately electrical gremlin got me. I noticed my volt gauge was lower than normal on the 2nd run... then it was fine on the 3rd run ...... then low again. I think the alternator is going bad. I checked connections under the hood, that did not help so far. Will have the alt tested if further home tests dont show the problem
Tony in AZ...
Gene Fiore
RC Moderator
Post #141 by Gene Fiore » Sun Oct 14, 2012 12:11 am
I ran a personal best today at Speedworld of 15.15 @88.60 mph. Made it to the semi-finals. :D
turbo2256b
Post #142 by turbo2256b » Sun Oct 14, 2012 10:57 am
Back in the years 67 and 68 at York US 30 Dragway.
200 67 Mustang Sprint, 3 speed , 3.20 gears, 775 x 14 tires (i think), adjustable rockers, carb from a 240, open exhaust. Possibly some other cheep mods. I would sell trophys I won for money to go back the next week to race. Still was in HS money was limited. My dad's car he didnt know I was racing it at that point in time.
Ran P stock later rule changes move the car to Q stock (possibly Q to P). Times were between 14.2 and 13.96 depending on how it hooked up that day.
82F100
Post #143 by 82F100 » Mon Oct 15, 2012 12:36 am
Crosley & Gene, congrats guys on the new personal bests Tpast weekend.we still have cooler weather ahead, wonder who might hit the 14's first 8)
Gene Fiore
RC Moderator
Post #144 by Gene Fiore » Mon Oct 15, 2012 9:57 am
82F100 wrote:Crosley & Gene, congrats guys on the new personal bests Tpast weekend.we still have cooler weather ahead, wonder who might hit the 14's first 8)
:hmmm: :hmmm: :hmmm: :hmmm:
Gene Fiore
RC Moderator
Post #145 by Gene Fiore » Sat Nov 10, 2012 9:05 pm
I set another new personal best today at Speedworld of 15.08 @89.20 mph.
Crosley
Post #146 by Crosley » Sat Nov 10, 2012 9:56 pm
I ran a 15.17 today. Odd though as some guy(me) ran his Falcon too low on fuel and the engine sputtered some the last couple hundred of feet to the traps.
Also, I shifted 1-2 at 5800 and run 2nd gear to near 6k RPM
Perhaps I need to lean the jetting out some?
Tony in AZ...
Gene Fiore
RC Moderator
Post #147 by Gene Fiore » Sat Nov 10, 2012 10:20 pm
Crosley wrote:I ran a 15.17 today. Odd though as some guy(me) ran his Falcon too low on fuel and the engine sputtered some the last couple hundred of feet to the traps.
Check your plugs and see how they look?
Hudson Nut
Post #148 by Hudson Nut » Sun Dec 09, 2012 3:38 am
14.67 @93.8 MPH. 1941 Hudson coupe. 353 cubic inch Hudson flathead six two holley 500cfm 2bbl carbs. 727 torgue flyte with a manual valve body. Ford 9in with 3.56 gears and 29" slicks.
Gene Fiore
RC Moderator
Post #149 by Gene Fiore » Sun Dec 09, 2012 12:47 pm
Hudson Nut wrote:14.67 @93.8 MPH. 1941 Hudson coupe. 353 cubic inch Hudson flathead six two holley 500cfm 2bbl carbs. 727 torgue flyte with a manual valve body. Ford 9in with 3.56 gears and 29" slicks.
Nice!!
Post #150 by THE FRENCHTOWN FLYER » Mon Dec 10, 2012 4:33 pm
What did you have to do to get the 727 to bolt up to the six? Why not a 904?
Well done.
