Post your best times
Moderator: Race Moderator
Hudson Nut
Re: Post your best times
Post #151 by Hudson Nut » Fri Dec 14, 2012 6:12 pm
The previous owner had the adapter made back in the 80's. It is aluminum, and bolts to the back of the engine, then the trans bolts to it. Im not sure why he used the 727.
Gene Fiore
RC Moderator
Post #152 by Gene Fiore » Sat Jan 12, 2013 9:42 pm
14.92 @ 89.61 mph on 1/12/2013... :D
1971 Maverick, 250I6, crank knife-edged, Clay Smith 278 solid cam, .040 over 255 V8 pistons, 10.5 to 1, Custom 500 Holley 2V on Classic Inlines Aluminum cylinder head, 1.6 rockers, Hooker header, DUI dizzy, C-4 w/2800 stall, 8" 3.55 det locker
Best ET 1/4 mile: 14.92 at 89.61 mph on 1/12/2013
My Classic Inlines Photo Page
Mustang_Geezer
RC Moderator
Post #153 by Mustang_Geezer » Sun Mar 03, 2013 7:39 pm
Heres my best timeslip from last August that I was finally able to scan and post!
It was in the high 80's when i made this pass.
Hopefully the thumbnail and link works!
Doug
1966 Mustang Coupe
206 ci Inline 6
Best ET 60' 1.84 1/8 mile 8.74 @ 79.09 mph 1/4 mile 13.67 @ 98.18 mph US 131 Motorsports Park. 4/6/13
2003 F-150 FX-4 Tow vehicle.
82F100
Post #154 by 82F100 » Sun Mar 03, 2013 8:34 pm
Doug, worked for me :D
300's make good truck motors....not race motors
Gene Fiore
RC Moderator
Post #155 by Gene Fiore » Sun Mar 03, 2013 11:05 pm
Yep...nice run!
THE FRENCHTOWN FLYER
Post #156 by THE FRENCHTOWN FLYER » Tue Mar 05, 2013 1:54 pm
Mustang_Geezer wrote:Heres my best timeslip from last August that I was finally able to scan and post!
Doug
wow! 94 mph
64falconsix
Post #157 by 64falconsix » Sun Apr 14, 2013 10:27 pm
first time out in Aug.09 ran 10.98@58.59 , This past saturday we ran a best of 10.29@61.91... 60' went down 1/10th of a sec from my previous fastest time. I think there is a 9.99 in there somewhere, maybe smaller diameter tires in the back, a distributor recurve, still had about about 3/8 tank of gas and the back seat with a few things in the trunk.could probably trim out 40 lbs plus of back seat and carpet, front and rear bumper and tools in the trunk. plus will be building an air box with an inlet to the grill. yeah and a good cool night I think breaking into the 9s is in reach.
64 falcon 2dr 200 C.I. .040 decked ,comp. 260 .440, C.I. adjustable timing chain w/ 79 log head 52.cc , offy w/ triple webers , Clifford header , D.U.I. , C/4 2,200 stall , Transgo Stage 2 reprogramming kit , 7 1/4" with 3.20 gears. NX, N2O 75HP shot.
10.29@ 61.91 M.P.H. in the 1/8th mile. 4/12/13
xrwagon
Post #158 by xrwagon » Tue Sep 17, 2013 12:38 am
Eighth mile run best pb 12.668 at 53.65, it was 86F, stock 46 year old bottom end, head has been off 8 years ago for unleaded conversion, untouched carb, dist, has a custom exhaust and ran with no air cleaner through 185/70/14 radials Motor hasn’t seen a timing light since i brought it, won my class though at The Six Banger Nats, also met a member from the forum who has the alloy head.
1967 XR Wagon Super Pursuit 1968 200/221 Head, Steel Shim headgasket/3spd Man/75 series Borg/Hi-Tech Headers/2.5 Collector 2.25 Hooker Aeroflow dumped at diff. PB 11.74 over Eighth 1/8 Mile
64 200 ranchero
Post #159 by 64 200 ranchero » Fri May 22, 2015 1:44 am
my old 200 ran a 11.677 on the 1/8th mile with the stock head and stock cam. my new time is 11.201 @ 60.77 with my new 200 tri-power. i did 2 passes, the first was manually shifted and the 2nd was auto 1-2 then i held 2nd to the finish
my reaction time was very bad on the first pass
R/T=1.478
60'=2.838
330=7.458
1/8=11.332
mph=57.50
R/T=.608
60'=2.713
330=7.353
1/8=11.201
mph=60.77
i think my combo should be able to do way better than this, i need to work on my technique for sure. :? my combo is in the signature
60 ford ranchero daily driver. 200 tri power, modified c4 trans, ds2 distributor, msd programable 6al2, weber ict's, 8" rear end with full spool, 3.80 gears, 245 tires, CI dual out header, Dynomax muffler, 114hp shot wet nitrous kit. JE Forged pistons, 280 110lc cam, around 11-1 compression.
Post #160 by THE FRENCHTOWN FLYER » Mon May 25, 2015 8:32 am
Leave as soon as you see the last yellow.
If that is not quick enough, deep stage by turning off the top pre-stage bulb.
More air pressure in the front tires will help too.
64 200 ranchero
Post #161 by 64 200 ranchero » Mon May 25, 2015 6:41 pm
thanks for the tips, i raced the car only once before and im still a newbie when it comes to racing, i now know that i need a stall converter if i ever want to get some decent times, I know my engine should be able to do much better, i also plan on installing f6 emulsion tubes in the carbs, i don't think that will give much performance but i think it will make tuning easy.
xrwagon
Post #162 by xrwagon » Sun May 31, 2015 4:55 am
My 3040 pound wagon with its stock bottom end, stock cam has run 2.438 in the sixty foot being a 3 speed manual and 3.5 stock rear, my way of shifting the weight is small diameter tyres on my stock rims, take my big 15’s off, and i have 90/10 shocks in front, i roll in the water and drop the clutch at probably 2500 rpm, don’t spin for very long, on the tree i rev mine to probably 3000-3500 rpm and drop the clutch, mine is shifted on the column still. I have the 2V head now and probably rd 30-40 more hp so i will have to redo my startling procedure, will need a bigger tyre, i have always only tired my car for the smallest tyre without wheelspin, so my 185/70/14s are great for the old log setup, that was all with the 1.5” log head and stock Stromberg carb, DUI dissy and modified extractors. Enjoy your racing guys. PS I have done 0.014 reaction times and run as close to 0.002 to a dial in and i don’t even have a tacho, i shift by speed in the gears, best with log head 11.74
Post #163 by THE FRENCHTOWN FLYER » Mon Jul 13, 2015 9:48 am
I am having the best season of my racing career. Yesterday I won my second race in the last month, this one being the National Dragster Challenge Race at Milan. I must be inspired by The Holy Spirit as I have not had a light slower than .025 in my last 24 rounds and the car has been deadly consistent. I have been tinkering with seemingly minor tweaks - like carb tuning, front shock rates, front tire pressure, etc. - and arrived at the car's sweet spot. (Only took 15 years)
Here's my Wally Jr:
On an even happier note Saturday was my grandson's birthday and his mom arranged for him and I to go flying in her friend's 1946 Taylorcraft. I want my sportplane pilot's license now.
Post #164 by bubba22349 » Mon Jul 13, 2015 12:27 pm
:beer: congrats on the Wally FTF, that's excellent news!
Even a bad day Drag Racing is still better than a good day at work!
Current project is a 1988 John Deere 420 Garden Tractor I need a few small parts to get it fixed, plus some cosmetic items, maybe a few attachments, if you happen to have or know of JD 420 parts would welcome the help!
My Ex-Inline 6 Fleet 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
Sick6Turbo
Post #165 by Sick6Turbo » Sat Dec 26, 2015 11:36 am
Great job, congratulations!!!
Dale
79 F-100 turbocharged 300 rear mount 20 psi
Stock EFI bottom end, mild port carb head
12.44@106 1/4 mile in 2015
Gene 64 2dr
Post #166 by Gene 64 2dr » Sat Dec 26, 2015 7:14 pm
Congratulations and good luck getting your sport certificate.
I would recommend going a bit future and get a private certificate. The added training I think is well worth it and opens up a lot more opportunities. I got mine this year a it's one of the best things I've ever done.
Gene
65 Falcon Futura hardtop, FSD’s 250, T5, 4:11’s
xrwagon
Post #167 by xrwagon » Sat Feb 13, 2016 9:51 pm
Hi all, last time out i raced my wagon she ran a 11.05 1/8th mile and a 17.2 1/4 qtr, never had full throttle again, 1968 motor getting a little tired, its been retired for now. imaging v8 and have a 393 Cleveland stroker on hand.
64 200 ranchero
Post #168 by 64 200 ranchero » Tue Sep 04, 2018 12:15 am
.556 rt
2.743 60'
7.082 330'
10.584 8th mile @ 68mph
Post #169 by xctasy » Sun Sep 09, 2018 4:56 am
64 200 ranchero wrote:.556 rt
2.743 60'
7.082 330'
Without reaction time, 10.55 secs for the 330 would be 16.46 secs Image
https://speedmaster79.com/tools/18et-mph/
68 mph is 10.45 sec on the 1/8 or 16,30 secs at a speed of at least 83.98 MPH.
http://members.tripod.com/fast_wheels/1-4speed.htm
The way to backwards check is Image
Or http://www.wallaceracing.com/etcalc.php
1.56 conversion factor. NHRA uses 1.6. See http://cochise.uia.net/pkelley2/eight-to-quarter.htm Generally, 7 secs = 10.92 secs; 8 secs = 12.48 secs; 9 secs = 14.04 secs ;10 sec = 15.60 secs ;11secs = 17.16 secs.
Lincs200 timecard was actually a 330 foot time card; it got on 13 psi
84.76 mph at 8.93 secs over the 1/8 th mile 330' and
to perhaps 20 psi....
92.68 mph at 13.879 sec over the 1/4 th mile 660'
So, um....when you turbo it, your gonna have to hang on a "little"
64 200 ranchero
Post #170 by 64 200 ranchero » Sun Sep 09, 2018 5:29 pm
My next time slip will be much better as long as I can keep traction. I have reinslled my 90hp nitrous jets and I will be running the water/meth injection to allow for more ignition advance. I have also been tweaking the carbs a little bit. :beer:
Post #171 by THE FRENCHTOWN FLYER » Mon Sep 17, 2018 1:57 pm
Just returned from the NHRA Div. 3 E.T. Finals at Indy. Made it to the fourth round. Every time I parked the car a crowd formed by it. I'm the only Super Pro competitor in the Midwest Division that runs a Ford six. Several folks said it was the most unique ride; a little boy said it was his favorite.
You can bling up and circus paint a rear engined dragster but somehow they all still look the same.
Ran 5.7s and .8s in the eighth @ 115+
64 200 ranchero
Post #172 by 64 200 ranchero » Fri Oct 26, 2018 7:36 pm
Twinturbor
Post #173 by Twinturbor » Sun Jul 21, 2019 2:07 am
14.68 300 turbo with a 5sp manual. The truck weighs 4750 and first get popped out for over 1 second. The boost was at 9psi
Users browsing this forum: No registered users and 9 guests
