Line Lock electrical
Moderator: Race Moderator
powerband
FSP Moderator
Post #1 by powerband » Tue Apr 25, 2017 9:06 pm
setting up a front wheel 'line lock' for occasional burnout box use. Is the switch at shifter typically momentary or a toggle SPST ? .
thanks
" Everything in my garage has a story ..."
Re: Line Lock electrical
Post #2 by bubba22349 » Tue Apr 25, 2017 9:55 pm
They are a push button "Momentary" Switch, some of the shifter knobs like a T handle can have them built in. The button holds or locks the front brakes for as long as you hold the button down. Good luck :nod:
Even a bad day Drag Racing is still better than a good day at work!
Current project is a 1988 John Deere 420 Garden Tractor I need a few small parts to get it fixed, plus some cosmetic items, maybe a few attachments, if you happen to have or know of JD 420 parts would welcome the help!
My Ex-Inline 6 Fleet 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
wsa111
FSP Moderator
Post #3 by wsa111 » Wed Apr 26, 2017 3:56 pm
A line lock allows you to take up all the backlash in the drive line. It is a life saver for diffs & transmissions.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
