engine perch interchange question
binder56jd
Post #1 by binder56jd » Wed Nov 11, 2009 3:57 pm
currently have 300 6 in 85 e150 van--may have to swap in 302 while rebuilding 300
which perches do I need??
i have 302 f150 perches--will they work in the van???
thanks
jd
I usta could
85 E150 4.9 1bbl c4
JackFish
Re: engine perch interchange question
Post #2 by JackFish » Wed Nov 11, 2009 6:45 pm
Would either of these work? What size ya lookin' fer...?
:P Sorry, couldn't help myself...
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
binder56jd
Post #3 by binder56jd » Wed Nov 11, 2009 7:19 pm
i ain't lol--u might consider changing your handle to richard cranium-- i will translate need be
in the mean time i still would like to know which engine things i need--call 'em perches--stands wtf--over
jd
btw--cute pics--bet none r u
I usta could
85 E150 4.9 1bbl c4
JackFish
Post #4 by JackFish » Wed Nov 11, 2009 9:08 pm
binder56jd wrote:i ain't lol--u might consider changing your handle to richard cranium-- i will translate need be
:rolflmao: I deserved that!
Sorry I can't help you, except that they're called engine mounts. :beer:
1999 Dodge Ram 2500
ludwig
Post #5 by ludwig » Wed Nov 11, 2009 10:21 pm
Are you saying 'motor mounts'? That support the block and keep it connected to the frame. The little cradles that support the coil springs in front are called 'spring perches'.
mutt
Post #6 by mutt » Thu Nov 12, 2009 12:30 pm
yeah, its motor mounts hes after. Beats me- the answer, that is.....
306
Post #7 by 306 » Fri Nov 13, 2009 12:59 am
I dont think truck mounts will work, but you can try. You need "perches" from the same van as yours that has a small block v8.
Lazy JW
FSP Moderator
Post #8 by Lazy JW » Fri Nov 13, 2009 8:03 am
binder56jd wrote:.....
i have 302 ..... perches
That a lotta fish...... :roll: :wink: :lol:
binder56jd
Post #9 by binder56jd » Fri Nov 13, 2009 2:20 pm
thanks--sorry about the lack of sense of humor--it really is funny--bad hair day
ps----found a pair at a local fish hatchery :D
I usta could
85 E150 4.9 1bbl c4
MaxRat
Post #10 by MaxRat » Sat Nov 14, 2009 8:15 pm
binder56jd wrote:currently have 300 6 in 85 e150 van--may have to swap in 302 while rebuilding 300
thanks
jd
you will need the frame mounts (perches) off a V8 E-Van for a 5.0L or 5.8L engine...
you will also need the matching motor mounts...
