Cargo van 1/2 Ton ??
Ecovan150
Post #1 by Ecovan150 » Tue Nov 02, 2010 1:11 am
on books always says that my van econoline 150 1984, is 1/2 ton , well my Question is...its all my van or !!! put stuff on my cargo please i dont understand that ... relly need help friends thanks ..... :?: :bang:
gbm35
Ford Econoline 150 six line engine 300cc 1984
C6 Transmission 2WD Cargo mini Van, 1/2 Ton
Luckyman
Re: Cargo van 1/2 Ton ??
Post #2 by Luckyman » Tue Nov 02, 2010 10:22 am
1/2 ton means it can safely carry 1,000 lbs of cargo continually and up to 2,000 lbs occasionally if the tires, brakes and springs are good. It probably weighs 3,800-4,200 lbs empty.
1 "76" F150 RC, LB, 2WD, 300, NP435, 9" open 3.00, special order 2-76/Delivered 4-76. Still "new".
1 "73-79" F150 RC/SS/SB/4WD, "84"-300, T18, NP205, 9" open 3.50, Dana 44 3.50 open, Offy DP, Holley 470, EFI + single 2.5" exhaust. Gathered from 15+ donor/parts trucks. "Fubar". Runs good, safe, still needs details/project continues.
Ecovan150
Post #3 by Ecovan150 » Tue Nov 02, 2010 3:34 pm
ok thanks friend for the information ok :nod:
gbm35
johnsons63
New Member
Post #4 by johnsons63 » Mon Dec 20, 2010 7:23 pm
Luckyman wrote:1/2 ton means it can safely carry 1,000 lbs of cargo continually and up to 2,000 lbs occasionally if the tires, brakes and springs are good. It probably weighs 3,800-4,200 lbs empty.
hi there im new here, thanks for this info. i was about to ask this also and gladly i found this thread...
Thanks again for this info...
_________________________________________________
93 Formula Mods: 383, LE2 Heads/Intake, 226/230 cam, 52MM TB, Magnaflow cat back, LT headers, aftermarket truck parts, CAI, SFC, Strut Brace, Adj LCA, Adj Panhard, Relocated Torque Arm, Progressive Rate Springs, Short Throw Shifter
Ecovan150
Post #5 by Ecovan150 » Mon Dec 20, 2010 10:19 pm
:nod: ok always thanks friend
gbm35
mwilliamshs
Post #6 by mwilliamshs » Thu Mar 12, 2015 8:11 pm
An E150 cargo should have an Allowable Weight or Payload (GVWR - Curb Weight) of 1,965 lbs in the heaviest SuperVan to 2,565 in the lightest short wheelbase model. An E100 (discontinued after 1983) would have had an Allowable Weight of about 1,260-1,795 lbs.
Half-Ton, Three-Quarter-Ton, etc are OLD nomenclature that's just been carried on out of tradition. F150's today are called half-ton trucks but have payloads of upto 2,200 lbs!
It's often suggested the names came from the front axle of trucks, not their payload capacity. Ford all the way back to Model TT trucks used front axle ratings. The TT was a "one ton" truck because it could carry one "short" ton (.91t) total and when the A trucks came out this increased further but an A truck with a TT axle was a one ton, the next step up was a 1.5 ton, and so on. There were only so many axles, engines, etc available in those days but every GVW class had a unique front end and above TT they shared a DRW, worm drive rear-ends, so the physical difference in GVW was the front axle.
Names changed and instead of using short tons, full tons were used so the smallest pickup was now half-ton. Names stick I guess.
1989 E-150 Extended Body SuperVan Sportsmobile Camper Conversion 4.9L, C6, 3.08 R&P
