62Ranchero200
Greetings Ford Six Fans,
I'm building up a 250 pump gas street engine for my '62 Ranchero. My original thought was to have a 2V conversion done on my '80 large log head, but the relative costs moved me towards picking up a CI aluminum head.
Trouble is, with the .123 deck height on the 250 and the 50 CC combustion chambers on the CI head, it's extremely difficult to get a good quench effect. Any rod, piston, and decking combination that moves the piston up towards zero deck height also raises the CR too high for a pump gas street engine.
If the combustion chamber of the CI head were larger, it would be easier to move the piston up towards zero deck height while maintaining a reasonable CR. Have any of you enlarged the combustion chambers on the CI head? IYO, does that compromise the flow and combustion characteristics of the head? What do you think the reasonable limit of enlarging the combustion chambers might be?
Thank you,
Bob the Builder
Thank you,
Bob the Builder
