AzCoupe":220n561i said:Your kit was one of the first ones made for a 69 Mustang. Unfortunately they didn't have a car to do an actual install on, so they had to use measurements from a V8 and guess at the modifications needed for the six. We rarely get any feedback from customers, so we have no idea what modifications are needed for a better fit. If you could send me an email with any of the details you remember about the install (modifications you had to make), I will forward the info to them. I'm sure it would be greatly appreciated. Thanks....
well, if they had simply put together the pipe once, they would have noticed that the angle of the x-pipe is wrong.
(the red line is showing the original fit out of the box)
of course we could not correct the angle of the x-pipe, so we had to rebend the pipe that came after the x-pipe and try to get the pipes as parallel as possible.
this was not 100% possible (see lenght of green and yellow line) but i'm happy with the result.
