If seems I have no luck what so ever. Is it any wonder why I have gray hair and ulcers.
They started machining the intakes last Monday, but before they completed the second one, a piece of tooling broke. Evidently it broke because it wasn't the right part for the job, but being the only thing they had, they tried to make it work.
According to the owner, when they tap the water bosses, the tooling bottoms out and binds, which snapped it in half on the second intake. As a result, they had to shut down and order a new one. Rather than ordering a stock replacement, which they could have gotten in one day, they decided to have custom tooling made so they don't run into the same problem. As much as I dislike the delay, I agreed with the call.
However, the timing couldn't have been worse. Both the foundry, who is doing the machining, and the tooling company work 4-10 work weeks. With the holidays, this means both companies are only working two days this week and next. Knowing how important this is to me, and all the other problems we've had to work through, the owner of the foundry called the owner of the tooling company and asked for a special favor. Normally it takes several weeks to get custom tooling made, but they promised to have it done by the end of the week, even if meant having someone come in and work on it today to get it done. Plans are to overnight it on Monday, so it will be there 1st thing Wed morning.
If, and this seems to be a big if, the tooling arrives on time they will start working on the intakes right after the holiday. He thinks they can run one every fifteen minutes, or four per hour. That means its going to take 25-26 hours to get the first batch done. Therefore they should complete them sometime Monday afternoon, the 7th. However, this is based on the tooling arriving on Wed morning as planned. They said they would call me Wed afternoon or Thursday morning and let me know how its going.
As such, my current plans are to drive down Monday afternoon (the 7th), and pick them up Tuesday morning. I also need to stop and pick up a crate full of custom oil pans, carb adaptors, t-stats, and a few other bits and pieces from Australia. But I should be on the road home Tuesday afternoon, which means I'll be shipping intakes on Wed, the 9th.
Sorry for the delay. Dare I ask "What next"?
