Any intake manifold for side draft webers for the Alum Head
If enough interest and people want one, I can make some of them. Im doing patternwork for several Cheby intakes right now. A Weber style intake like that would be fairly easy to make and have cast. I already have the intake ports drawn and in a DWG file, so im halfway there already....
CNC Dude:
After casting up the 3xDCOE manifold(s), I wonder if you could develop an alternate plenum that would bolt up instead of the Webers, and then have several plenum top plates for various combinations of carbs or throttle bodies? Perhaps a way to leverage the triple Weber manifold effort ...
Russ
Scott:
If done right, the plenum tops could apply to any inline six you built 3xDOCE manifolds for. The plenum might have to be a bit different for each application due to the difference in intake port spacing but they should all be similar.
Russ
