Have the CI Aluminum head on the 200 and have bolted up the stock rocker arms with stock push rods. Can't see a way to verify that the everything is adjusted properly. I assume (yeah I know) that the stock head had just the right dimensions for the everything to bolt together and the lifters be adjusted properly. Is this the situation on the CI Aluminum head, or do I need new push rods? Got the adjustable push rod set from CI when I bought my head, but it doesn't have "Ball Ends" at both ends of the rod, so it's worthless to me.
Keith "Shin" Schindler
South Central Texas
South Central Texas
