62Ranchero200
Greetings Ford Six Fans,
I placed my order last night for an assembled CI aluminum head with the single springs with dampers (STY) and the full ARP stud kit. The CI web site says that the single springs with dampers are good for cams with duration below 280, and will work with the high ratio rockers. Since mine will be a street build, I do not believe I will ever run one of the 280 or 292 duration cams.
Mike reports that the head could be ready as soon as two months, although it could also be longer.
Now I have to get my 250 short block build on track so that the short block is ready by the time the head is ready. I also need to get a 157 tooth bellhousing and torque converter for my case fill C4. I did not order the intake and carb adapter yet since Mike reports that he keeps those in stock and I can order one when I get my aluminum head.
Bob the Builder
Bob the Builder
