Triple Mikuni 45 intakes
jlopes
Does anyone know if there are intakes for 3 side mounted Mikuni carbs for the CI AL head. I believe they should be the same as the intakes for the Weber DCOEs.
I know this is a different head ("Oz pre x-flow") but take a look at the 1st pic in the 2nd group of pic (after the mag. repro & at the head on the blue towel)
viewtopic.php?f=48&t=71241
It shows one adaptation of the head for welding on some tubes, then plates - to serve as a base for other co.'s intakes (Lynx, Batteman) for larger market carbs (SU & Webers). A 2 step process like this is a hassel but 1 way it was/is being done. The Offie currently in production wrks w/o cutting off the log for triple down drafts
I think 6 Mikunis have been placed directly @ the ports of a sawed off log and there are some flow charts/numbers recorded (40 yrs ago?).
Further down in this thread R pic of other carbs and the 2 intakes (ALL on these OZ heads which R out of production. I think the Lynx & Batteman R out too but the Batteman would not fit in our engine bays).
- -Chad ('from' "'the inline sm 6 performance/tech forum")
