2018 Contributors:
Bypass carb water heater?
65coupei6
Assistant Admin
Post #1 by 65coupei6 » Mon Jan 15, 2018 7:58 pm
With the intake so close to the shock tower. I am guessing most people just bypassed the heater hose connections on the intake.
I know there was a discussion about this with the log head. But, I don't think there will any effect on my install since I live in a warm climate.
Any input?
...Marco
'65 Mustang Inline 200. VI (CI) Aluminum Head, Holley 350, Schneider 264/274 cam,
Headers, DSII, MSD 6A, and a whole lotta other stuff!
Build That Six With Parts From VintageInlines.com
grendi_250ci
Re: Bypass carb water heater?
Post #2 by grendi_250ci » Tue Feb 27, 2018 2:36 pm
I had to mill the water chamber away, as there was simply no space in my 69 mustang.
'69 Mustang Hardtop L-Code CI modified, DUI, Cliffords Headers, CI 1.75" dual exhaust, Borgeson Power Stearing, CRSP Brakes :-D
ludwig
Post #3 by ludwig » Tue Feb 27, 2018 3:29 pm
If you are talking about that base plate between the carb and intake log with the hose nipples front and back, you can leave the hose off. It does make a difference in really cold climates. In Cali, not so much. I just ran the heater hoses to the firewall and back.
If you are talking about the water-heated choke pull off, you probably need to keep that hooked up. Unless you can get by without a choke. I found it helpful.
ludwig
Post #4 by ludwig » Tue Feb 27, 2018 3:29 pm
double post
