2018 Contributors:
Video & Article(Mustang360): April 2018 Vintage Inline Performance Aluminum Cylinder Head
ray6966
Post #1 by ray6966 » Mon Apr 16, 2018 8:16 pm
Hi guys,
Mustang360 posted an Article and Video regarding the Vintage Inline cylinder head. Dated April 2018
Link: http://www.mustangandfords.com/how-to/e ... cylinders/
have a good day.
Ray
Southern California.
:D :beer: :arrow:
62Ranchero200
Triple side-draft Weber manifold for aluminum head
Post #2 by 62Ranchero200 » Wed Apr 18, 2018 10:25 am
@ray6966,
That was a nice article! Although, it gave the impression that the aluminum head just became available, when actually the first heads were shipped at least 5 1/2 years ago (I received mine from Classic Inlines in late winter 2012 or early spring 2013). My aluminum head is installed on a 250 in a '62 Ranchero, behind a T-5 and an 8".
The article mentioned a triple side-draft Weber manifold, but I can't find that on the Vintage Inlines website - does anyone know if this is available for sale yet? Has anyone installed one? I would be very interested in this setup; it seems like it would offer better fuel distribution and possibly better performance than my Holley 2-V setup, although I know nothing about Weber side-draft carbs, correct fuel pressure for these carbs, fuel line plumbing or how to fabricate throttle linkage.
Bob
62 Ranchero, 252 cid, 300 rods, RaceTek pstns, ARP mains bolts & studs, balanced & blueprinted, CI AL head, 1.6 adj rckrs, Smith Bros, 274/274/108 cam, CI int, Holley 500, DSII, CI SS hdrs, PowerMaster strtr and 1wire alt, Optima, V8 rad, T-5z, 10" organic clutch, 5 lug 8" w/3.80 Trac Loc, rear drums, front 5 lug discs, Centerlines. Next: ?.
ray6966
Re: Video & Article(Mustang360): April 2018 Vintage Inline Performance Aluminum Cylinder Head
Post #3 by ray6966 » Thu Apr 19, 2018 2:21 pm
I haven't seen anything on the triple side-draft Weber manifold either.
:D :beer: :arrow:
rocklord
Post #4 by rocklord » Thu Apr 19, 2018 3:48 pm
In the video Matt states that the triple weber and triple SU manifolds are available from Australia.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
2017 BMW X3, 3.0L Dual Turbo, 300HP, 8-Spd Auto
gb500
Re: Triple side-draft Weber manifold for aluminum head
Post #5 by gb500 » Thu Apr 19, 2018 9:32 pm
62Ranchero200 wrote:@ray6966,
Bob
that triple weber manifold in the article looks -when I squint- as though it says 'lynx' on the side :
so maybe not a vintage inlines one anyway.
Lynx in Australia do 2v weber maniolds
$581.90 Australian peso's = approx. $435 USD
https://www.lynxauto.com.au/ford-6-cyl- ... ifold.html
62Ranchero200
Post #6 by 62Ranchero200 » Fri Apr 20, 2018 3:45 pm
Bob
Thank you @rocklord,
Seems like, since these are for aussie 2V heads, they wouldn't fit the aluminum heads without serious modifications. This was a bit misleading in the online article, which seemed to imply that this manifold would fit the aluminum head.
Thank you,
Bob
CNC-Dude
Post #7 by CNC-Dude » Fri Apr 20, 2018 4:13 pm
I think I remember reading some time back that Mike made the aluminum head share the same bolt pattern and intake port spacing as the 2V Aussie head so it would have crossover possibilities for more intake selection without him having to actually make them all himself. Keep in mind that the patterns were both originally made, and the heads were first cast in Oz, so it stands to reason this is a valid and purposeful design trait made into the Classic Inlines head. Can anyone confirm or deny this?
Post #8 by bubba22349 » Fri Apr 20, 2018 4:35 pm
Yes the C.I. Head was based on the Australian 2V port head design! :thumbup: :nod:
chad
V I Aluminum Head + other's adapter
Post #9 by chad » Thu May 03, 2018 7:24 pm
I think I saw an intake frm GB but am no help beyond that. It's too far in the back of my mind, too long ago, my altzhimers, etc. :arg:
SynchromeshWines
New Member
Post #10 by SynchromeshWines » Fri May 04, 2018 12:46 am
I have recently received mine. Ordered along with a lynx triple su manifold supplied by Matt at vintage inlines. Linkage was included and just a small amount of port matching needed to blend the intake to the head.
This is going into a 67 mgb with at T5 sp HS6 Su carbs seemed more at home than webbers. Plus I'm better at tuning them. I think matt also has triple webber intakes.
chad
V.I. has two 'flatter" intakes for multi carbs
Post #11 by chad » Fri May 04, 2018 8:50 am
depending on which Webers - itsn't it a tight fit w/the pass's shock tower? One or
2 of the DCOEs might B tight in there - just remove the stack on it (or both)? The 3rd - OK?
There's a early '70s 4 cyl Celica w/a turbo'n 3 DCOEs, been over in the corner a decade...they
look long to me (6, 8 inches?).
