Nope, that's about the size of it as far as I can tell. Who knows what politics happened there, but Vizard is no stranger to ruffling feathers; mostly when some manufacturer gets upset for him demonstrating that their stuff doesn't work as advertised. BTW, it is 8 to 10 times the volume of one cylinder. For us 200 type folks, that's between 266 and 333 CI. Flowmaster makes a few suitable candidates for an easy solution.
So, going by Vizards calculations and the dimensions of my Clifford dual out header (which only has primaries) I get the following:
* Primaries are 1.5" diameter and average out to 21" in length measured from the exhaust valve.
* That means my secondaries should be 1.5 x 1.68 = 2.5", and about the same length as the primaries.
* That means my exhaust should be 2.5 x 1.68 = 4" (!!!) and about 36" long, dumping into a roughly 300 ci termination box, and then out to whatever will flow adequately.
Well, those are the numbers according to his latest book, although it focuses on 4:1 headers so the extra step is probably throwing me off. My gut tells me this is insanely huge for a 6000 rpm motor, so this is my plan:
*Secondaries at 2.25" and 21" long
*y-adapter 2.25 to either 2.5" or 3" for 36" into the can.
3" still seems really big, although plenty of V-8 run that size and bigger with only 152ci per bank, so... Nevertheless, I think I'll err on the side of small and make my pipe 2.5" into a single-in/dual-out can and then out to dual 2" through some porter mufflers.
As a point of comparison, my current exhaust dumps the header outs into a 2" to 2" y adapter with only 8" of length and then steps up to a 2.25" exhaust about 45" to a turbo muffler. Pretty ugly. I wonder why my new awesome engine didn't make the power I expected.
So, I'm going to hand make this intermediate section and have it ceramic coated to match my header. Should be pretty sweet and certainly a better match for my high-revving engine.
