2018 Contributors:
CA - Bay area - LOYD ENGINEERING
RichCreations
Post #1 by RichCreations » Mon Feb 08, 2016 8:52 pm
Reasonable prices, very good work! Builds engines for a lot of local circle track guys, recommended to me separately by several people. Did an amazing job cleaning/boring/honing/decking my block.
Loyd Engineering
3780 Main St. Oakley, CA
925-625-0100
http://www.loydengineering.com
69stang_250
Re: CA - Bay area - LOYD ENGINEERING
Post #2 by 69stang_250 » Tue Feb 09, 2016 12:44 pm
What is their turn around time usually?
69 mustang coupe, 250 .030 over, forged pistons, port & polished CI AL head 54cc's 10.25CR, 280/280 Clay smith cam 1 degree advanced, 1.6 adjustable rockers,
Re curved DSII, MSD AL6, CI Intake, FITech 400HP fuel injection. T5 trans, 8" rearend w/3.80 gears, Eaton trutrack.
RichCreations
Post #3 by RichCreations » Tue Feb 09, 2016 4:33 pm
It is a small shop, so I am sure it varies, but I dropped my block off friday, it was ready tuesday.
They even managed to clean all the rust scale out of the water jackets.
Cleaned the block, bore/hone, decked, main/head threads chased, installed new freeze plugs, new cam bearings, broken timing cover bolt removed/rethreaded all for $300.
69stang_250
Post #4 by 69stang_250 » Tue Feb 09, 2016 6:07 pm
That is not bad at all.
RichCreations
Post #5 by RichCreations » Tue Feb 09, 2016 6:18 pm
I knew I was dealing with a good shop, when several friends unrelated to each other (in different walks of life) recommended them as their first choice, including one who lives in sacramento.
69stang_250
Post #6 by 69stang_250 » Tue Feb 09, 2016 6:26 pm
I am here is the bay area for a temp time and I have had no help from any of the shops around this area.
There is a guy down in Livermore that is building my head right now. Not sure how the outcome will be, but he has been around for a long time, so i hope he does a good job.
