Sct pro racer software/ sct x4
sthorvictor
Post #1 by sthorvictor » Wed Apr 11, 2018 1:40 am
More of a generic question, hopefully someone has some input and or advice.
To begin I have been using an sct x4 handheld flash tuner/ data logger for the past three to four years to run my turbocharged maf 4.9l eecv. Recently I have been debating heavily to convert to a micro squirt or ms2 stand alone. Or purchase the sct pro racer software to program using the x4.. the data logging is easy enough to use and see what’s going on when it’s uploaded, nothing is real-time of course...to this point I have been remotely tuning, and frankly it’s a pita and not quite perfect. Any small changes are a huge process. Curious if anyone here has ventured Down this path or not? Thanks again!
Best of luck,
Seth
turbocharged maf 300 f150
Wesman07
Re: Sct pro racer software/ sct x4
Post #2 by Wesman07 » Wed Apr 18, 2018 5:17 am
I have been looking into my options for quite some time now. The “stinger pimp” is a ms3 box that is already set up to run OBD1 fords. It is a little more pricey than ms3 alone, but should be worth the hassle in my opinion.
In-lines we trust
86 f150 300 efi with advanced stock cam. Np435, Dana 60/ 10.25, 35" BFG's, four link front suspension with 12" travel fox coil overs, custom deaver leaf pack in the rear.
