Anyone here successfully running an aftermarket EFI System, Megasquirt, Holley Hp, Sniper, Atomic, FITech?
clintonvillian
Post #1 by clintonvillian » Tue Feb 12, 2019 9:16 am
Just curious if anyone is running any of the above.
I can't imagine that someone hasn't put one of the new self learning systems on a six, but I am not seeing anything.
maxtrux
Location: Home is in OK, but currently working in Sacramento, CA
Re: Anyone here successfully running an aftermarket EFI System, Megasquirt, Holley Hp, Sniper, Atomic, FITech?
Post #2 by maxtrux » Tue Feb 12, 2019 12:51 pm
I was planning on running a 4 bbl but have been rethinking the idea. I am contemplating using a FiTech system. I spoke with a guy that successfully ran one on a 2.3 Liter Pinto motor. Before I do that, I will be conferring with Bruce and Paul to get their input. It will cost more, but I'd really like this to be nice when I get finished. If anyone is wanting to stay on a tight budget, then obviously the carb is the way to go.
68 F100 300 auto; '78 T'bird 28K original miles; '86 F350 5.9 Cummins; '93 Lightning Turbo coming soon; '94 Mark VIII w/nitrous; '98 Ram V6 43K My dad's last truck; '99 Navigator; 2000 Excursion V10; 2011 F350 6.7; 2017 F350 6.7
Reckon my next one should be from the 50s but I do love the early 60s falcon
67Straightsix
Post #3 by 67Straightsix » Tue Feb 12, 2019 10:06 pm
I'm using Holley HP. Once I got the fuel map dialed in the car starts right up,and runs smooth. I Don't have very many miles on it, but so far I'm happy with it.
ahawks9er
Post #4 by ahawks9er » Wed Feb 13, 2019 2:26 pm
There are quite a few threads of folks on here successfully running megasquirt and other systems. Some w/turbos, distributorless ign, etc.
Project92
New Member
Post #5 by Project92 » Sat Mar 02, 2019 7:43 pm
I'm running FiTech 4bbl on my 300. I've only test ran it on the engine for an hour or two but once everything was wired and setup correctly it ran pretty decent. I'm pretty impressed so far by it. I'm curious to see someone run the 2bbl version.
clintonvillian
Post #6 by clintonvillian » Mon Mar 25, 2019 2:28 pm
What are you running for a distributor?
Are you letting the Snipe control timing?
AbandonedBronco
Post #7 by AbandonedBronco » Mon Apr 08, 2019 5:36 pm
Yes, I have a Holley Sniper 850-550 on my 300.
I'd had a 4bbl carb on it for years, so I wavered back and forth between going with the 4bbl Sniper or the 2bbl Sniper, but was then advised by both forum members, and Holley, to go with the 2bbl setup since it's rated for 350hp (which is plenty for me) and flows 580cfm. Unlike a carb, it doesn't depend on air speed through the venturi to get crisp throttle response like a carb does, so a "big" 2bbl design works just great.
I very much like it. It fired right up from the first turn of the key, and has been a joy to drive since. I've never had such crisp throttle response. Plus, the cold weather options and drivability leaves the carb to shame.
I also love all the data I can read and pull up on the handheld. Engine vacuum/pressure, AFR, coolant temp, air temp, RPM, throttle %, fuel flow rate, battery voltage, just to name a few, as well as the data-logging to view and look over later.
For the fuel system, I used the system from a '85 302v8 since it was fuel injected, and in my body style / era.
1985 Ford Bronco Eddie Bauer. 300 I6. 9.1:1 CR, roller rockers, EFI manifolds and 2.5" exhaust. DUI ignition. 3.55 final drive, 5 speed ZF5. Holley Sniper EFI w/Offenhauser C Intake. 32" BFG KO2 A/Ts.
Twinturbor
Post #8 by Twinturbor » Mon Apr 15, 2019 1:40 pm
I'm using ms2 extra on my turbo 300. Pretty easy to use and very easy to wire up
clintonvillian
Post #9 by clintonvillian » Wed Apr 17, 2019 1:54 pm
Twinturbor wrote:I'm using ms2 extra on my turbo 300. Pretty easy to use and very easy to wire up
How far along are you?
jimmyv65
Post #10 by jimmyv65 » Wed Apr 17, 2019 2:18 pm
I am running Megasquirt on a 250 I6. I documented the install FI Install
1966 Bronco-'78 250-Meagsquirted TBI, DUI, Header, Cam, Hydroboost & Front Disc, Uncut, 1" body lift, 2.0" suspension lift
