LincolnMarkVII":151oxxjr said:Sorry if this is too much of a thread derailment.. but I couldn't decide if this was better here, or merited its own thread. I'll copy it to its own thread if needed. Also, apologies if it's hard to read.. caffeine hasn't kicked in yet.
1) Do those Tempo throttle bodies have to be used with the non-upgradable injectors in them, or could they be used just as a small dry throttle body with an injector bung welded into the manifold nearby? (or multiples for multiport)
2) What about running a 250 almost like two separate turbo inline-3s? What I had in mind was two small unconnected intake manifolds (say on the CI aluminum head or an Oz head, or a heavily modified log) each with its own small throttle body.. then two small unconnected exhaust manifolds each with its own turbo from a 2-liter engine. I realize this description may annoy some, but the best way I can think to describe the intakes is to make something looking like the Mopar logo M, put the throttle body where the three legs meet, and put the injector below the TB pointing down the inside of the middle leg. (I can try to draw a diagram if I've been too vague in my description)
I'm guessing sensors may have to be doubled up.. and that it's more complicated than a single TB and larger turbo.. but would there be any benefit to doing it like that if it's feasible, even if that benefit is something not immediately obvious like saving weight vs. a larger manifold? Also, if you've read my thread on my plans to build for low revs, (idle to 4000) would the really short intake lengths negatively impact that?
The only thing that I know is, runner length has little to no impact on turbo tuning. The pressure waves just aren't there in a boosted application like they are in N/A engines.
EDIT: Now that I look into it a little more, the basic rules still apply. But it is not nearly as critical.
