So, I was looking at the extrudabody site and at Moe$ TEmpo conversion and wondering if a single extrudabody would be a nice way to make a TBI unit. 1-3/4 = 44.45mm, so you could slap a 45mm throttle body right on a head and have a pretty smooth flow, and I'm fairly certain that a single injector could handle the needs of a typical loghead 200. If not, they also make standoffs to add a second injector above the throttle plate. http://www.extrudabody.biz/servlet/the- ... %29/Detail
Wouldn't be too expensive, either:
Extrudabody unit, w/air horn and adapter plate: $159
Injector: $75
TPS: $40
Fuel rail w/ fittings:$75 (or you could make one cheaper)
Not sure that there would be any advantages over a TEmpo unit, but it sure looks cool
Injector: $75
TPS: $40
