I just got my '67 mustang 200ci 6 CYL running on the megasquirt (just ignition for now), but I would really like to see what others are using for the megatune basic ignition settings with a duraspark ii distributor. I am using the vr pickup in the duraspark ii distributor and controling the neg terminal of the coil. Currently my ignition offset is 65 degrees which is way too much, but the timing was way off with the megasquirt. Physically the distributor is 20 degrees advanced.
Thanks,
Greg
Thanks,
Greg
