Everyone is in love with the GM TBI. Well, i got one and decided it would not be a good choice for my mod-log head because the base is too big and the spacing between the butterflies is too wide. Here is a comparison between the TBI gasket and that of the weber, which is what my head is presetnly configured for. As you can see, I'd have to make a funneling adapter to make it work. Plus, the clearance with the valve cover is questionable.
So I picked up a CFI unit from a 3.8 v-6. Now look at the weber gasket on the CFI gasket.
As you can see, the spacing of the butterflies is nearly perfect. What;s more, the placement of the bolt holes on the CFI and the Weber are different enough to make an easy adapter plate that won't leak at the bolt holes. Of course, if your head is already set up for a Holley, then this is a no-brainer because the mount is identical.
Here is a look at how the bottom of the TBI, the CFI, and the weber compare. this is a 32/36, but I'll be replacing a 38/38. The barrels on the CFI are about 39/39, but with much less venturi it must be capable of much more flow than the weber.
CFI v. TBI. Obvioulsy, the TBI can flow waaaay more than the CFI, and if I had an aluminum head I'd go TBI, but for a log head this should be ample.
Other views:
The "choke" unit. Actually opens the butterflies, so not a choke. More of a crude fast-idle device.
Here is a fast idle actuator. Won't work with the MS (although I'm sure there is a way using a relay or something). I think it is intended to compensate for A/C. Won't be using it.
In the hood clearance competition the Tempo unit wins. Probably a great setup for unmodified heads up to 150hp, too.
Other views:
