Army of Six
*posted at MS forums also..
I have been running with fuel only for a while now and decided to try and run spark control. it is a Ford 240 that has a points distributor BUT i pulled the points and am running a pertronix unit. I pulled the vacuum advance, i pulled the mechanical advance weights and added heavy springs to keep the base plate from advancing.
for wiring i have the red wire of the petronix to the pos coil, the black wire of the pertronix to the tach input WITH a 1K pullup resistor. and i am running the from the relay board S5 terminal to the neg side of the coil.
i am getting RPMs a while cranking and fuel but no spark output. all my other tables and setting are pretty much like in the mega manual
any ideas?
any ideas?
