SoCar72
Has anyone used one the PowerJection III's or know of someone who has? For any application for that matter.
The specs read convincing and it seems to be a very elegant design. The throttle body is rated for 750cfm (stating to support up to 550hp). Obviously this is well sized for the small block applications, perhaps even for the 300's. I'm wondering how well it may work on small cube engines. Since the fuel discharge is not contingent on venturi vacuum, assuming the injectors are not too large and the ECM can calibrate for the lesser flow, it seems the large throttle body may not necessarily be too large to work. The system does have a standard computer link port for user end custom programming. I've requested info from Professional Products about this possibility, albeit after their business hours.
Also, PP claims the throttle body is good for pressures up to 2.5 bars, 22 psi boost for those forcing it. If you boost a 200 that far you'll be using the bulk of the TB's capacity, either drawing or blowing.
The TB is based on the Holley 4150 squarebore flange. Other than that adaptation (CI head and manifold or other custom job) it seems plausible.
I've never seen first hand any aftermarket EFI system. I'm open to any comments...
