I'm building a turbo 300 for my 78 ford half ton. I've got a carbed engine and a 96 Obdii mass air engine. What's my best option for engine managment? Megasquirt? Moates quarterhorse? Holley hp?
You will need a system that will work with a 2 bar MAP sensor.
The MS3 is the least expensive and has all the features you need including "coil on" ignition.
I am recommending a distributor-less ignition system because distributor phasing can be a real pain with a turbo system where there is a large swing in timing.
My personal preference would be the Electromotive TECgt
