85 f150 No power, sometimes cuts in and back out?
85Beast6
Post #1 by 85Beast6 » Sun Sep 27, 2015 9:05 pm
My truck isn't getting any power. It has a new battery, starter, alternator, and starter solenoid. This happened all of a sudden one day after stopping at the gas station and it wouldn't start. Sometimes it gets power but not enough to start but to make the door buzzer start buzzing again. No power to head lights. Anyone have this problem? Is it maybe in the steering column ignition? I had a shop working on it one week before replace the carb with one that didn't have elec. Could there be a problem from that? it was working. Anyways, if you have any advice you can share please let me know. Thanks for your time.
-Justin
Re: 85 f150 No power, sometimes cuts in and back out?
Post #2 by bubba22349 » Mon Sep 28, 2015 2:20 am
Yes I would definitely check out the ignition switch to see if its still working correctly. That would also include the linkage from the key unit down to the switch itself or it might only need to be adjusted at the switch because of wear. I.e. It's not moving the ignition switch internally to the corect position to touch the contacts to start or run. Also if the switch is older it might be worn out and time to replace it too. Good luck :nod:
85Beast6
Post #3 by 85Beast6 » Sun Oct 04, 2015 9:49 pm
Well I replaced the ignition switch and key unit and there is still no power at all. :bang:
JackFish
Post #4 by JackFish » Sun Oct 04, 2015 10:37 pm
Maybe a ground problem.
Start at the battery and work your way around the electrical, wiggling and inspecting all the wires and connections.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
Lazy JW
FSP Moderator
Post #5 by Lazy JW » Wed Oct 07, 2015 11:02 pm
Is there a fusible link in the system?
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
Econoline
Post #6 by Econoline » Mon Oct 19, 2015 3:30 am
I had a problem like this with my 93 f150, went on for almost a year. Intermident cutting out of power, it would blink out going down the road sometimes. Couldn't figure it out. It turned out to be a smallish ground wire that goes to the fender near the battery. I never looked into what it went to, figured it out by luck poking around up there when it was acting up one night bad and I was stuck on a country road with the light disappearing fast. But it sure fixed it tightening it up, been a few years now, still fine. That wire being disconnected/lose would kill everything on the truck, including the ignition.
It ain't gonna fix itself
1964 Econoline 170 3.03 on the tree swapped to a 250 with an aod, custom front boosted disc brakes and 3.70 9" rear axle
1993 F-150 xl 4x4 4.9 5-speed, Mazda manual stock
1992 Jeep Cherokee 2-door 4.0, 5-speed manual
1989 Toyota Cressida 3.0, auto
