T5 backup switch wiring
69stang_250
Post #1 by 69stang_250 » Mon Dec 05, 2016 1:27 pm
Hey guys. Does it mater which way you connect the 12v switched wire and the backup light wire to the backup switch terminals on a t5 trans?
69 mustang coupe, 250 .030 over, forged pistons, port & polished CI AL head 54cc's 10.25CR, 280/280 Clay smith cam 1 degree advanced, 1.6 adjustable rockers,
Re curved DSII, MSD AL6, CI Intake, FITech 400HP fuel injection. T5 trans, 8" rearend w/3.80 gears, Eaton trutrack.
Re: T5 backup switch wiring
Post #2 by bubba22349 » Mon Dec 05, 2016 7:32 pm
69stang_250 wrote:Hey guys. Does it mater which way you connect the 12v switched wire and the backup light wire to the backup switch terminals on a t5 trans?
It dosent matter which wire is hooked up to which one of the switch terminals. Good luck :nod:
