2018 Contributors:
New wiring no headlight switch?
papawfalcon
Post #1 by papawfalcon » Wed Jul 26, 2017 10:57 pm
I am in the process of putting aftermarket wiring in my Ranchero. What I would like to do is eliminate the headlight switch and run the headlights off of the ignition switch so on with ignition like new cars? Can this be done my headlight wiring has relay?Thanks!
FALCONS AND RANCHERO'S FOREVER
Re: New wiring no headlight switch?
Post #2 by bubba22349 » Fri Jul 28, 2017 1:54 am
Sure it can be done! All you need is for power to come from the ignistion switch (in the run position) to trigger your headlite relay. Good luck :nod:
Users browsing this forum: No registered users and 7 guests
