2018 Contributors:
Old Sears Dwell/Tach/Voltmeter model 161.2124 has three leads??
F6 lathead
Post #1 by F6 lathead » Thu Feb 01, 2018 1:09 am
I am getting ready to do a tune up and need to figure out the three leads on my old Sears Dwell/Tach/Voltmeter equipment. This particular one has a black and a red alligator clip and then a smaller green clip. I am not sure where the hook ups go? does anyone know where they go and for what purpose? I've checked You Tube but the ones they had there only had two leads, and black and a red, or a black and a green. Thanks
mustang6
Re: Old Sears Dwell/Tach/Voltmeter model 161.2124 has three leads??
Post #2 by mustang6 » Thu Feb 01, 2018 4:08 am
Black is ground, red is battery positive, green is the trigger side of the points.
Scott
mustang6
Post #3 by mustang6 » Thu Feb 01, 2018 4:10 am
mustang6 wrote:Black is ground, red is battery positive, green is the points side of the coil.
Scott
F6 lathead
Post #4 by F6 lathead » Thu Feb 01, 2018 9:18 am
hey thanks, I am going to assume that the trigger side is the distributor side of the coil? the wire that comes from the distributor?
F6 lathead
Post #5 by F6 lathead » Thu Feb 01, 2018 9:22 am
also, will this hook up give me all three functions of the equipment? ie. tach, dwell, and voltmeter? only reason I ask is because in some of the manuals for different diagnostic equipment it says to put the connections (two connections) in different places. Thanks again.
F6 lathead
Post #6 by F6 lathead » Thu Feb 01, 2018 4:13 pm
ok just answered my own question, I went out and hooked it up no problem, got the dwell where I want it, rpms. thanks
