2018 Contributors:
Loose Wires within Engine Compartment
jkelley
Post #1 by jkelley » Wed Mar 14, 2018 8:57 pm
Im still working on the 1986 Ford F-150 , 300 Inline 6 , 3 speed , Carb , that's been sitting for a long time, I keep coming across wores that are disconnected that I have no Idea where they go ?...Can anyone Chime in and Help?
1986 Ford F-150 4x2 , 300 Inline 6, 3 speed on the Floor , 3.08 Gear Ratio ,80,000 original Miles One owner ,NO AC
Re: Loose Wires within Engine Compartment
Post #2 by bubba22349 » Wed Mar 14, 2018 10:10 pm
Having worked on the Ford assembly line many years ago I can tell you that offen not all those wires / plugs are going to be connected. It's going to depend on the parts and accessories that your truck was equipped with. Your best bet is to see if you can find a factory wiring diagram on line. Other sources are if you have a local library, a Hynes manual that cover your truck year also has the wiring diagrams. Good luck :thumbup: :nod:
