2018 Contributors:
1952 Ammeter not working
Robdewey
New Member
Post #1 by Robdewey » Sun Aug 12, 2018 1:40 pm
I have a 52 Mainline that I've gotten everything working perfectly now except the ammeter. It just has one insulated wire that runs through an open loop on the back of the gauge then is connected to a post on multi post block. Looks to be all original setup, needle moves freely by hand, wire does have power when ignition is on but gauge never moves. Any thoughts or suggestions greatly appreciated. Thx Rob
Lazy JW
FSP Moderator
Re: 1952 Ammeter not working
Post #2 by Lazy JW » Mon Sep 24, 2018 1:47 pm
The gauge is bad. I do not know where to get them repaired. Sorry. :cry:
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
B RON CO
Post #3 by B RON CO » Tue Sep 25, 2018 4:03 pm
Hi, see if a moving a magnet along the back of the gauge will move the needle. The magnetic field will do the same thing as the electric field.
The gauges are rugged and foolproof.
A 35 amp gauge is pretty sensitive. A 60 amp gauge may only be moving a tiny amount.
If you just can't get it to work you will have to replace it.
good luck
1966 Ford Mustang - 289 V8
wsa111
FSP Moderator
Post #4 by wsa111 » Thu Oct 18, 2018 4:30 pm
Place an add for one in the wanted section of the forum. Check ebay.
https://www.macsautoparts.com/ford_truc ... FUQAvD_BwE
