3.03 gearbox extension housing length
Post #1 by xctasy » Sun Mar 05, 2017 8:07 pm
I don't have one, but the 1966 to 1973 9 bolt 3 speed Toploader extension housings used on our 3.03 gearboxes...are they 14, 15.5 or 17" long?
Its the same as the AMC Hornets and Gremlins with 150-T.
Is it basically interchangabe with the 4 speed TopLoader?
vssman
Re: 3.03 gearbox extension housing length
Post #2 by vssman » Thu Mar 09, 2017 12:03 pm
I have a 3.03 sitting in my basement and can get the measurement for you. I just have to remember to do it. If you haven't heard back from me, send me a PM
63 Falcon 'vert running a 68 200CID Tri carb and a few other goodies
Post #3 by xctasy » Fri Mar 10, 2017 12:33 am
No worries. Don't get lost....I'm not used to getting info right away...its kinda hard to find the info on the net, everyone talks 4 speeds, but the little 3.03 is more plentifull than all the others.... :thumbup:
vssman
Post #4 by vssman » Fri Mar 10, 2017 4:53 pm
From the face of the transmission case to the rear of the face where the seal is installed is 14 3/4" on mine. Photos are available if needed. If you feel like visiting cold Connecticut, I have one in my basement for you... :lol:
vssman
Post #5 by vssman » Sat Mar 11, 2017 6:56 am
Photos I PM you posted for anyone else needing this info...
Post #6 by xctasy » Thu Apr 20, 2017 10:33 pm
Thanks.
viewtopic.php?t=41637
jamyers wrote:Here are the 3.03 gear ratios for 6-cylinder models, V8-s had taller ratios.
First 2.99
Second 1.75
Third 1.00
Reverse 3.17
The 3.03 manual is also known as a RAN gearbox, from the casting codes on the side. Best way to id one in the car is by the casting codes.
Edit: Those ratios were in Bronco versions, but I think they were same for Mustangs/Falcons.
I'm looking at a GearVendors overdrive, a 0.78:1 ratio hike on the stock ratios above, to create a quasi TKO 6 speed.
1st Gear: -----------------> 2.99
2nd Gear (OD Ist): -------> 2.33
3rd Gear: (2nd)-----------> 1.75
4th Gear: (OD 2nd)-------> 1.37
5th Gear: (3rd )----------> 1.00
6th Gear: (OD 3rd)-------> 0.78
It doesn't quite do it as a close ratio TKO 6 Speed, as the first three ratios differ by 11.3 to 4 %, but not far off...
1st Gear: 2.66;(in terms of the ratios above, 3.33) vs 2.99 11.3 % to steep (taller geared than ideal)
2nd Gear: 1.78;(in terms of the ratios above, 2.22) vs 2.33 5% too shallow (lower geared than ideal)
3rd Gear: 1.30;(in terms of the ratios above, 1.63) vs 1.75 7.4% too shallow (lower geared than ideal)
4th Gear: 1.00;(in terms of the ratios above, 1.25) vs 1.37 9.6% too shallow (lower geared than ideal)
5th Gear: 0.80;(in terms of the ratios above, 1.00) same
6th Gear: 0.63(in terms of the ratios above, 0.79) almost the same
Users browsing this forum: Google [Bot] and 3 guests
