Gear Ratio
lovemy95
Gear Ratio
Post #1 by lovemy95 » Tue Mar 06, 2018 11:20 pm
Interested in a 6” lift and 35” tires on my 1995 F-150 XL - L6 - 4.9L - 300ci. It is currently stock. What gear ratio should I run? Current gear ratio is 3.08. Thank you!
rocklord
Re: Gear Ratio
Post #2 by rocklord » Wed Mar 07, 2018 9:22 am
Do you have an overdrive transmission?
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
2017 BMW X3, 3.0L Dual Turbo, 300HP, 8-Spd Auto
Shorty
Re: Gear Ratio
Post #3 by Shorty » Wed Mar 07, 2018 6:55 pm
the carrier in the front has a split at about 3.73 or somewhere around there and if you go lower you will need a new carrier. Maybe time for a selectable diff locker?
85 F150 on 78 bronco frame C6 np205 welded dana44 front, trussed posi nine inch rear. EFI exhaust manifolds into one 2 1/2" rolls on 35x12.5x15 Maxxis Trepador.
lovemy95
Re: Gear Ratio
Post #4 by lovemy95 » Mon Mar 12, 2018 4:56 am
I think I’ve decided to just go with some 31”s and buy a bigger truck later down the line. 31”s should fit the stock height and gear ratio right?
Shorty
Re: Gear Ratio
Post #5 by Shorty » Mon Mar 12, 2018 12:36 pm
31s will fit fine and work well with the od trans and 3.08 gear ratio. Depending on the width and offset of rims you use you may find they will rub the radius arms in the front when turned to the stops but one quickly learns not to turn as sharp
Users browsing this forum: No registered users and 7 guests
